Save not working properly
Robert Newton
When I opened the "1st Attempt 3D Model.2dwg" file you provided in post #11 above, and checked the UCSFOLLOW variable, it was set to 1, so I changed it to 0.
I also set the SKYSTATUS variable to 0. In your file it was set to 2. In order to set it to 0, you must first set it to 1, and then set it to 0. You can't go directly from 2 to 0.
Changing UCSFOLLOW and SKYSTATUS fixed the saving problem for me, but I see that the zoom extents issue is still happening. Just run a PURGE and delete the blocks. You will have to PURGE twice in order to eliminate all the blocks. That should fix the zoom extents issue.
  • Replies 24
  • Robert Newton
    13
  • ReMark
    4
  • Cad64
    4
  • Dadgad
    2
Posted Images
The attached images indicate that I have done as directed and still no luck with Zoom Extents. Thanks to all of you have had input on attempting to correct my problem.
