Results 1 to 9 of 9
    Junior Member
    AutoCAD 2010
    Apr 2009
    21
    Default Hatching over text
    Hi,
    I've searched several forums looking for a lisp routine that can hatch a text boundary but can't find anything. I need to hatch directly over text and/or mtext. Is there anything out there that will allow me to hatch the text within the boundaries that would normally be used as a mask, or in the case of mtext...the text background boundary?
    Thanks,
    rob
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,602
    Wouldn't disabling island detection allow you to hatch over text?
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,215
    Hi,
    For background mask check this.
    For overlapping IMO its easy to provide a solution.
    Junior Member
    AutoCAD 2010
    Apr 2009
    21
    Basically, I want to be able to select the text or mtext as a valid boundary.
  5. #5
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,215
    I'm not sure what do you mean by boundary. Here are few scenarios:
    hatching over (using boundingbox)
    hatching below (using boundary)
  6. #6
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 7 Pro x64
    HP ZBook 17
    i7-4810MQ @ 2.80 GHZ
    16GB
    Nvidia Quadro K4100M
    256GB SSD
    1TB SATA
    (2) HP 23"
    Civil
    rkmcswain's Discipline Details
    Civil
    CAD Manager
    Civil 3D 2017
    Sep 2005
    Houston
    4,462
    Something like this?
    R.K. McSwain
    CAD Panacea | twitter
  7. #7
    Junior Member
    AutoCAD 2010
    Apr 2009
    21
    Quote Originally Posted by rkmcswain View Post
    Yes, rkmcswain...exactly like that...with the ability to work mtext as well.
    @grrr...a boundary that is used/generated when using the wipeout from the textmask command.
  8. #8
    Windows 7 Pro x64
    HP ZBook 17
    16GB
    256GB SSD
    1TB SATA
    (2) HP 23"
    Civil
    Civil
    CAD Manager
    Civil 3D 2017
    Sep 2005
    Houston
    4,462
    This is mostly some code I had for doing something similar at one time.
    It will essentially work for any selected object, and of course there is no error checking here.
    Code:
    (defun c:foo ( / sel obj var1 var2 pt1 pt2)
      (setq sel (entsel))
      (setq obj (vlax-ename->vla-object (car sel)))
      (vlax-invoke-method obj 'GetBoundingBox 'var1 'var2)
      (setq pt1 (vlax-safearray->list var1)
    	pt2 (vlax-safearray->list var2)
      (vl-cmdf "bhatch" "_W" "_N"
    	   pt1
    	   (list (car pt1)(cadr pt2))
    	   pt2
    	   (list (car pt2)(cadr pt1))
    	   "_C"
    	   "_P"
    	   "ANSI35"
    	   "1.0"
    	   "0.0"
    R.K. McSwain
  9. #9
    Junior Member
    AutoCAD 2010
    Apr 2009
    21
    Code:
      (setq sel (entsel))
    	   pt1
    	   pt2
    	   "_C"
    	   "_P"
    	   "ANSI35"
    	   "1.0"
    	   "0.0"
    Thanks! That works great! I made an adjustment for the pattern type...but still very much what I was looking for.
  1. Hatching and blank areas around text
    By acjam in forum AutoCAD Beginners' Area
    Last Post: 15th May 2015, 06:59 pm
  2. Text over hatching Help
    By Dibz in forum AutoCAD Beginners' Area
    Last Post: 26th Jul 2010, 05:18 pm
  3. Text & Solid Fill Hatching
    By gortex in forum AutoCAD Drawing Management & Output
    Last Post: 12th Dec 2006, 08:17 pm
  4. Hatching
    By gortex in forum AutoCAD Beginners' Area
    Last Post: 10th May 2006, 10:01 pm
  5. HATCHING AND TEXT
    By stewartthorp in forum AutoCAD General
    Last Post: 21st Sep 2004, 09:55 pm
