Results 1 to 4 of 4
    Senior Member ziele_o2k's Avatar
    AutoCAD 2016
    Jun 2014
    Poland
    104
    Default Handle INI files with lisp challenge (without acet)
    Hey,
    In my software I'm using ini files. I wrote my own routines to handle them, because I don't like tu use acet/doslib. It would be great if somone would wrote functions simillar to acet-get-ini / acet-set-ini or dos_getini / dos_setini or both...
    It's just an idea! Unfortunately I don't have time to do that, and (also and more important) i don't need those routines. Although it would be great to have that stuff
    Maybe some one will take this post as challenge ?
    EDIT:
    I can post info about where to find documentation for acet / doslib functions
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,011
    Its (defun getini ( filename key / )) write your own version as a rule INI file is just a text file.
    I have some library text files one has 200+ lines in it and its formatted in a way that you can find the value of a known "Key"
    Code:
     eg use a comma seperated you can use TAB also
    Key1,value1
    or by position
    12345678901234567890
    key1 Value1 Colour Linetype
    AutoCAD 2016
    Jun 2014
    Poland
    104
    Ok,
    based on this Lee Mac's code i wrote something like this:
    1) pz:INI-Read
    Read ini file to formated list - slighty modified XParseConfig by Lee Mac.
    Semicolons ( ; ) and number signs ( # ) at the beginning of the line indicate a comment.
    Code:
    (defun pz:INI-Read ( file / line sub lst i m )
      (if (and (setq file (findfile file)) (setq file (open file "r")))
          (while (setq line (read-line file))
            (cond
              ( (wcmatch line "`[*`]")
                (if sub (setq lst (cons (reverse sub) lst)))
                (setq sub (list (substr line 2 (- (strlen line) 2))))
              ( (and (/= (substr line 1 1) ";") (/= (substr line 1 1) "#") (wcmatch line "*=*"))
                (setq i 0)
                (while (/= "=" (substr line (setq i (1+ i)) 1)))
                (setq sub (cons (list (substr line 1 (1- i)) (substr line (1+ i))) sub))
              ( (setq sub (cons (list line) sub)) )
          (close file)
      (reverse lst)
    2) pz:INI-Get
    If section is nil, a list of section names is returned.
    If key is nil, a list of keys for the specified section is returned.
    If key is not found, default is returned.
    Otherwise, a string associated with key is returned.
    Code:
    (defun pz:INI-Get ( file section key default / alist res )
      (if
        (and
          (=(type file) 'STR)
          (setq alist (pz:INI-Read file))
        (cond
          ( (not section)
            (foreach %1 alist
              (if (= (type (car %1)) 'STR)
                (setq res (cons (car %1) res))
            (reverse res)
          ( (and (not key) (assoc section alist))
            (foreach %2 (cdr(assoc section alist))
              (if (= (length %2) 2)
                (setq res (cons (car %2) res))
            (reverse res)
          ( (setq section (cdr (assoc section alist)))
            (if (setq res (assoc key section))
              (setq res (cadr res ))
              (setq res default)
            res
        nil
    3) pz:INI-Set
    section: A string containing the name of the section for the given data. If the section does not exist, it will be created.
    key: A string containing the name of the key to be associated with a value. If the key does not exist in the given section,
    it will be created.
    Code:
    (defun pz:INI-Set ( file section key value / alist sectionl i )
      (if
        (and
          (=(type file) 'STR)
          (=(type section) 'STR)
          (=(type key) 'STR)
          (=(type value) 'STR)
          (if (setq sectionl (assoc section alist))
            (setq
              sectionl (cdr sectionl)
              sectionl
              (if (assoc key sectionl)
                (subst (list key value) (assoc key sectionl) sectionl)
                ;(reverse (append (list(list key value)) (reverse sectionl) ))
                  (setq i (1-(length sectionl)))
                  (while (= (length(nth i sectionl)) 1)
                    (setq i (1- i))
                  (cd:LST_InsertItem (1+ i) sectionl (list key value))
              alist (subst (cons section sectionl) (assoc section alist) alist)
            (setq alist (reverse (append (list(list section (list key value))) (reverse alist) )))
          (if (and (setq file (findfile file)) (setq file (open file "w")))
              (foreach section alist
                (if (= (type (car section)) 'STR)
                    (write-line (strcat "[" (car section) "]") file)
                    (foreach key (cdr section)
                      (write-line (if (cadr key) (strcat (car key) "=" (cadr key)) (car key)) file)
                  (foreach key section
              (not (close file))
        nil
    4) pz:INI-Del
    In progress
    one subroutine needed
    Code:
    (defun cd:LST_InsertItem (Pos Lst New / res)
      (if (< -1 Pos (1+ (length Lst)))
          (repeat Pos
            (setq res (cons (car Lst) res)
                  Lst (cdr Lst)
          (append (reverse res) (list New) Lst)
        Lst
    AutoCAD 2016
    Jun 2014
    Poland
    104
    Ok this is final i hope
    How should it work:
    - function will keep ini file formatting (tabs/spaces)
    - section and kay names are case insensitive
    - comments can start with ; or #
    Example of ini file (to test my *ini* functions please create file example.ini in cad search path) :
    Code:
     #I hope
      #it will be
      [SECTION1]
      KEY1  = VALUE 1_1
        ;useful
      KEY2  =
      KEY3  = VALUE 1_3
        [SECTION2]
     KEY1 = VALUE 2_1
    KEY2    = VALUE 2_2
    KEY3=VALUE 2_3
    [SECTION3]
    KEY1=VALUE 3_1
      KEY2=VALUE 3_2
    KEY3=VALUE 3_3
            [SECTION4]
    KEY1    =   VALUE 4_1
    KEY2    =   VALUE 4_2
    KEY3    =   VALUE 4_3
       ;for someone
    My *ini* functions (based on source given in third post)
    Code:
    ; (pz:INI-Get file section key value)                                                         ;
    ;  file    [STR]     - short or full path file name                                           ;
    ;  section [STR/nil] - name of section to read key                                            ;
    ;                      if nil then function will return all section names from .ini file      ;
    ;  key     [STR/nil] - name of key to read value                                              ;
    ;                      if nil then function will return all key names from section            ;
    ;                      if key value is "" then returns nil                                    ;
    ;  value   [STR/nil] - default value if section or key not found                              ;
    ; (pz:INI-Get "example.ini" "SECTION1" "KEY2" nil)                                            ;
    (defun pz:INI-Get ( file section key value / l res tmpl )
      (if (and section (=(type section) 'STR))
        (setq section (strcat "[" section "]"))
      (if (setq l (pz:INI-Read file))
        (cond
          ( (not section)
            (foreach %1 l
                (setq res
                  (cons
                    (substr
                      (pz:TrimStr (car %1))
                      2
                      (- (strlen (pz:TrimStr (car %1))) 2)
                    res
            (setq res (reverse res))
          ( (and
              (not key)
              (setq tmpl (pz:AssocCI section l))
            (foreach %1 (cdr tmpl)
              (if (= (length %1) 2)
                (setq res (cons (pz:TrimStr(car %1)) res))
          ( (and
              key
              (setq section (cdr (pz:AssocCI section l)))
            (if (setq res (pz:AssocCI key section))
              (if (= (setq res (pz:TrimStr(cadr res))) "")
                (setq res nil)
              (setq res value)
          ( T (setq res value))
        (setq res value)
      res
    Code:
    ; (pz:INI-Set file section key value)                                                         ;
    ;  section [STR] - name of section to set key value                                           ;
    ;  key     [STR] - name of key to set value                                                   ;
    ;  value   [STR] - value to set                                                               ;
    ; If section not found then function will create section with given key and value             ;
    ; If key in given section not found, function will create key with supplied value in section  ;
    ; (pz:INI-Set "example.ini" "SECTION1" "KEY2" "Value 1_2")                                    ;
    (defun pz:INI-Set ( file section key value / l sl fvalue i )
      (if
        (and
          (=(type file) 'STR)
          (=(type key) 'STR)
          (if (setq sl (pz:AssocCI section l))
            (setq
              sl (cdr sl)
              sl
              (if (pz:AssocCI key sl)
                  (setq
                    fvalue (vl-string-subst value (pz:TrimStr(cadr(pz:AssocCI key sl))) (cadr(pz:AssocCI key sl)))
                  (subst
                    (list (car(pz:AssocCI key sl)) fvalue)
                    (pz:AssocCI key sl)
                    sl
                  (setq i (1-(length sl)))
                  (while (= (length(nth i sl)) 1)
                    (setq i (1- i))
                  (cd:LST_InsertItem (1+ i) sl (list key value))
              l (subst (cons (car(pz:AssocCI section l)) sl) (pz:AssocCI section l) l)
            (setq l (reverse (append (list(list (car(pz:AssocCI section l)) (list key value))) (reverse l) )))
              (foreach %1 l
                    (write-line (car %1) file)
                    (foreach key (cdr %1)
                  (foreach key %1
              (not (close file))
        nil
    Code:
    ; (pz:INI-Del file section key value)                                                         ;
    ;  section [STR]     - name of section to delete key or key value                             ;
    ;  key     [STR/nil] - name of key to delete value or key                                     ;
    ;                      if nil then function will delete whole section with all it's keys      ;
    ;                      but will leave comments                                                ;
    ;  value   [nil/T]   - nil - delete key with value                                            ;
    ;                      T   - delete only value of given key                                   ;
    ; (pz:INI-Del "example.ini" "SECTION4" "KEY2" nil)                                            ;
    (defun pz:INI-Del ( file section key value / l sectionlst sectionl  )
      (if
        (and
          (=(type file) 'STR)
            nil
        (cond
          ( (not key)
            (setq
              sectionlst (pz:AssocCI section l )
              sectionlst
              (vl-remove-if-not
                '(lambda (%1)
                  (if (=(type %1) 'LIST)
                    (=(length %1) 1)
                    nil
                sectionlst
              l (subst sectionlst (pz:AssocCI section l) l)
          ( (not value)
            (if
              (and
                (setq
                  sectionl (cdr(pz:AssocCI section l ))
                (pz:AssocCI key sectionl)
              (setq
                sectionl (vl-remove (pz:AssocCI key sectionl) sectionl)
                l (subst (cons (car(pz:AssocCI section l)) sectionl) (pz:AssocCI section l) l)
          ( T
            (if
              (and
                (setq
              (setq sectionl
                (subst
                  (list (car(pz:AssocCI key sectionl)) "")
                  sectionl
          (foreach %1 l
              (foreach key %1
          (not (close file))
    To run
    pz:INI-Get / pz:INI-Set / pz:INI-Del
    these Subroutines have to be loaded
    Code:
    ; Subroutines        ;
    (defun pz:TrimStr ( s )
      (vl-string-trim " \t" s)
    (defun pz:AssocCI (e l / )
      (vl-some
        '(lambda (%1)
          (if
            (and
              (= (strcase e) (strcase (pz:TrimStr(car %1) )) )
            %1
        l
    (defun pz:INI-Read ( f / l res sub i )
      (if
        (and
          (setq l (cd:SYS_ReadFile nil f))
          (= (type l) 'LIST)
          (foreach %1 l
            (cond
              ( (and
                  (/= (substr (pz:TrimStr %1) 1 1) ";")
                  (/= (substr (pz:TrimStr %1) 1 1) "#")
                  (wcmatch (pz:TrimStr %1) "`[*`]")
                (if sub
                  (setq res (cons (reverse sub) res))
                (setq sub (list %1))
              ( (and
                  (wcmatch %1 "*=*")
                (setq i 0)
                (while (/= "=" (substr %1 (setq i (1+ i)) 1)))
                (setq sub (cons (list (substr %1 1 (1- i)) (substr %1 (1+ i))) sub))
              ((setq sub (cons (list %1) sub)))
          (if sub (setq res (cons (reverse sub) res)))
      (reverse res)
    ; Subroutines from:        ;
    ; CADPL-Pack-v1.lsp        ;
    ; Czyta plik tekstowy / Read a text file                                                      ;
    ;  Line [INT/nil] - INT = numer linii pliku / file line number                                ;
    ;                   nil = caly plik / all lines of file                                       ;
    ;  File [STR]     - nazwa pliku (krotka lub ze sciezka) / short or full path file name        ;
    ; Zwraca / Return:        ;
    ;   nil = gdy Line = INT wieksze niz ilosc linii w pliku lub plik jest pusty /                ;
    ;         when Line = INT is greater then number of lines in file or file is empty            ;
    ;     0 = brak dostepu do pliku / no access to file                                           ;
    ;    -1 = nie znaleziono pliku / file not found                                               ;
    ;   STR = gdy Line = INT / when Line = INT                                                    ;
    ;  LIST = gdy Line = nil / when Line = nil                                                    ;
    ; (cd:SYS_ReadFile nil "data.ini"), (cd:SYS_ReadFile 10 "acad.lin")                           ;
    (defun cd:SYS_ReadFile (Line File / fn fd l res)
      (if (setq fn (findfile File))
        (if (setq fd (open fn "r"))
            (if Line
                (repeat Line (read-line fd))
                (setq res (read-line fd))
                (setq l T)
                (while l
                  (setq res
                    (cons
                      (setq l (read-line fd))
                      res
                (setq res (reverse (cdr res)))
            (close fd)
          (setq res 0)
        (setq res -1)
      res
    ; Wstawia nowy element na liste / Inserts a new item in the list                              ;
    ;  Pos [INT]  - pozycja elementu / element position                                           ;
    ;  Lst[LIST] - lista wejsciowa / input list                                                  ;
    ;  New[LIST/INT/REAL/STR/ENAME] - nowy element / new item                                    ;
    ; (cd:LST_InsertItem 3 (list 0 1 2 4 5) 3)                                                    ;
          (repeat Pos
                  Lst (cdr Lst)
        Lst
  1. after loding lisp : "error no function definition , ACET-STR-FORMAT"
    By Salama in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Mar 2014, 11:03 pm
  2. Acet- functions family... help me & help files
    By danie7LT in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Jul 2013, 04:04 pm
  3. New Challenge! Lisp for Tags.
    By tomhamlet in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Nov 2012, 02:50 pm
  4. the challenge lisp
    By motee-z in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Jan 2012, 04:41 pm
  5. acet-help not loading from Lisp
    By slimpickinz in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Oct 2009, 04:22 am
