Results 1 to 9 of 9
    Forum Newbie
    Architectural
    AutoCAD LT 2009
    Dec 2016
    6
    Default I want to add "center alignment" to this lisp
    Hello. I got this lisp here, and I've been using this very well.
    This lisp has center alignment.
    when I use this, this lisp aligns selected objects both X value and Y value.
    BUT
    I'd like to align objects only by X value.
    Could I get this?
    (defun c:AA (/ ActDoc Sel AliObj AliLl AliUr ss AliOpt Ent tempObj tempLl tempUr)
    (vl-load-com)
    (setq ActDoc (vla-get-ActiveDocument (vlax-get-Acad-Object)))
    (vla-EndUndoMark ActDoc)
    (vla-StartUndoMark ActDoc)
    (if
    (and
    (setq Sel (entsel "\n Select base object (for aligning): "))
    (not (redraw (car Sel) 3))
    (setq AliObj (vlax-ename->vla-object (car Sel)))
    (not (vla-GetBoundingBox AliObj 'AliLl 'AliUr))
    (setq AliLl (safearray-value AliLl))
    (setq AliUr (safearray-value AliUr))
    (setq ss (ssget))
    (not (initget "Left Right Center Top Bottom"))
    (setq AliOpt
    (if (setq AliOpt (getkword "\n Alignment option [Center / Left / Right / Top / Bottom]: <Center> "))
    AliOpt
    "Center"
    (setq cnt -1)
    (while (setq Ent (ssname ss (setq cnt (1+ cnt))))
    (setq tempObj (vlax-ename->vla-object Ent))
    (vla-GetBoundingBox tempObj 'tempLl 'tempUr)
    (setq tempLl (safearray-value tempLl))
    (setq tempUr (safearray-value tempUr))
    (cond
    ((= AliOpt "Center")
    (vlax-invoke
    tempObj
    'Move
    (mapcar '(lambda (a b) (/ (+ a b) 2.0)) tempLl tempUr)
    (mapcar '(lambda (a b) (/ (+ a b) 2.0)) AliLl AliUr)
    ((= AliOpt "Left")
    (vlax-invoke
    tempObj
    'Move
    tempLl
    (list
    (car AliLl)
    (cadr tempLl)
    (caddr tempLl)
    ((= AliOpt "Right")
    (vlax-invoke
    tempObj
    'Move
    tempUr
    (list
    (car AliUr)
    (cadr tempUr)
    (caddr tempUr)
    ((= AliOpt "Top")
    (vlax-invoke
    tempObj
    'Move
    tempUr
    (list
    (car tempUr)
    (cadr AliUr)
    (caddr tempUr)
    ((= AliOpt "Bottom")
    (vlax-invoke
    tempObj
    'Move
    tempLl
    (list
    (car tempLl)
    (cadr AliLl)
    (caddr tempLl)
    (if Sel (redraw (car Sel) 4))
    (prompt "\nEnter AO to start.")
    Forum Newbie
    Architectural
    AutoCAD LT 2009
    Dec 2016
    6
    If the alignment could be added to that lisp, I'd like to name it "Middle(M)".
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    744
    1st Wrap [CODE] tags around selected text using # from Toolbar above.
    2nd Paste the link to where you got the lisp. It gives credit to the author and provides more information about the lisp.
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,215
    Thats a nice code, just found the source thread and the author is Tim Willey.
    Anyway heres my attempt:
    Code:
    ; Align Objects with Justification
    (defun C:test ( / m mv *error* Lst s SS c acDoc i o d Lst2 sBL sTR dBL dTR)
      (defun m (p1 p2) (apply 'mapcar (cons '(lambda (a b) (/ (+ a b) 2.)) (list p1 p2))))
      (defun mv (o p1 p2) (vlax-invoke o 'move p1 p2))
      (defun *error* (m) (and acDoc (vla-EndUndoMark acDoc))(print m)(princ))
      (setq Lst
        (list
          (cons "Left" '((d) (list (cadr d) (list (car (car s)) (cadr (cadr d)) (caddr (cadr d))))))
          (cons "Center" '((d) (list (cadddr d) (list (car (caddr s)) (cadr (cadddr d)) (caddr (cadddr d))))))
          (cons "Right" '((d) (list (caddr d) (list (car (cadr s)) (cadr (caddr d)) (caddr (caddr d))))))
          (cons "Top" '((d) (list (caddr d) (list (car (caddr d)) (cadr (cadr s)) (caddr (caddr d))))))
          (cons "Middle" '((d) (list (cadddr d) (list (car (cadddr d)) (cadr (caddr s)) (caddr (cadddr d))))))
          (cons "Bottom" '((d) (list (cadr d) (list (car (cadr d)) (cadr (car s)) (caddr (cadr d))))))
      (setvar 'errno 0)
      (while (/= 52 (getvar 'errno))
        (setq s (car (entsel "\nSelect base object for aligning <exit>: ")))
        (cond
          ((= 7 (getvar 'errno)) (princ "\nMissed.") (setvar 'errno 0))
            (and s
              (or
                (not (vlax-method-applicable-p (vlax-ename->vla-object s) 'GetBoundingBox))
                (vl-catch-all-error-p (vl-catch-all-apply 'vla-GetBoundingBox (list (vlax-ename->vla-object s) 'sBL 'sTR)))
            (princ "\nInvalid object.")
          (s
            (and
              (setq s (mapcar 'safearray-value (list sBL sTR)))
              (setq s (append s (list (apply 'm s))))
              (princ "\nSelect objects to be aligned: ")
              (setq SS (ssget "_:L"))
              (not (initget (apply 'strcat (mapcar '(lambda (x) (strcat x " ")) (mapcar 'car Lst)))))
              (or
                (setq c
                  (getkword
                    (strcat
                      "\nSpecify alignment option ["
                      (vl-string-right-trim "/" (apply 'strcat (mapcar '(lambda (x) (strcat x "/")) (mapcar 'car Lst))))
                      "]: <Center> "
                (setq c "Center")
                (repeat (setq i (sslength SS))
                  (and
                    (vlax-method-applicable-p (setq o (vlax-ename->vla-object (ssname SS (setq i (1- i))))) 'GetBoundingBox)
                    (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-GetBoundingBox (list o 'dBL 'dTR))))
                    (setq d (mapcar 'safearray-value (list dBL dTR))) ; o BL TR MC
                    (setq d (append (list o) d (list (apply 'm d))))
                    (setq Lst2 (cons d Lst2))
                  ); and
                ); repeat
                (if Lst2
                    (setq acDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
                    (or (/= 8 (logand (getvar 'undoctl) 8)) (not (vla-EndUndoMark acDoc)) )
                    (not (vla-StartUndoMark acDoc))
                    (mapcar '(lambda (x) (apply 'mv (append (list (car x)) ((cdr (assoc c Lst)) x)))) Lst2)
                    (and (= 8 (logand (getvar 'undoctl) 8)) (vla-EndUndoMark acDoc))
            ); and
            (setvar 'errno 52)
      ); while
    ); defun
  5. #5
    Forum Newbie
    Architectural
    AutoCAD LT 2009
    Dec 2016
    6
    Thank you! I will follow the rules here next time
  6. #6
    Forum Newbie
    Architectural
    AutoCAD LT 2009
    Dec 2016
    6
    Grrr. I really appreciate what you did.
    Could I ask you to add one more thing ?
    I'd like to add "Inner center" that works as "Center" of the previous LISP. And I hope that "the inner center" will be the default option.
    ex) Alignment option [Left / Center / Right / Top / Middel / Bottom / Inner center]: <Inner center>
    If you have some free time, would you help me?
  7. #7
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,215
    For "Match Center" include this in the Lst variable:
    Code:
    (cons "MatchCenter" '((d) (list (cadddr d) (caddr s))))
  8. #8
    Forum Newbie
    Architectural
    AutoCAD LT 2009
    Dec 2016
    6
    That is just What I wanted!
    I'm really i really appreciate you doing so, Grrr
    Have a nice day!
  9. #9
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,870
    Please read the Code Posting Guidelines and edit your Code to be included in Code Tags.[CODE]Your Code Here[/CODE] =
    Code:
    Your Code Here
  1. Dimension center of "wall" best practices
    By ColtM16A1 in forum AutoCAD Beginners' Area
    Last Post: 25th Aug 2015, 08:38 pm
  2. HELP to include "AcDbAlignedDimension" code for a "Dimension deleting" LISP
    By vernonlee in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Apr 2015, 04:03 pm
  3. little "green dot" at center of x y axis is missing
    By mperry in forum Autodesk Inventor
    Last Post: 29th Nov 2012, 06:41 pm
  4. Inventor "Content Center" Question
    By AGMore in forum Autodesk Inventor
    Last Post: 16th Apr 2012, 05:17 pm
  5. Replies: 6
    Last Post: 10th Sep 2010, 04:16 am
