Results 1 to 10 of 10
    Senior Member gS7's Avatar
    gS7's Computer Details
    Windows Xp sp3
    4 GB
    Viewsonic
    Surveying
    gS7's Discipline Details
    Drafts man / Surveyor
    Surveying
    AutoCAD 2009
    May 2012
    Udupi,INDIA
    238
    Idea Create Batch file
    Hi,
    Is that Possible to create batch file , when double click the file
    open autocad exe and run lisp file from specified directory ?
    Please reply
    Ganesh Shetty
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    658
    Yes i think this can be done.
    You can have AutoCAD start up with a lisp program.
    In combination with windows scripting.
    But what is the real objective / the tasks that needs to be done, if i may ask?
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
    Windows Xp sp3
    4 GB
    Viewsonic
    Surveying
    Surveying
    AutoCAD 2009
    May 2012
    Udupi,INDIA
    238
    Hi halam Thank you for quick reply
    I have created XXX.lsp , XXX.mnu, XXX.mnl and I want to load menu file directly when open AutoCad (for First time only)
    so I asked for .Bat file codes
    and I found a code but its giving error when I run the file
    Code:
      start "t" /w "C:\Program Files\Autodesk\AutoCAD 2014\acad.exe" %%V /b  "D:\1.scr"
    Error : cannot find the Specified Drawing file
    please verify that the file exists
    Ganesh Shetty
    AutoCAD 2017
    Jul 2015
    658
    Sorry, i can't help you tith a fully complete answer, i'm not an 'administrator'
    Bu watch out for the notation of / or // or \ or \\ .. as little help in the direction.
    https://forums.autodesk.com/t5/autoc...e/td-p/2837855
    quote
    Code:
    (vl-load-com)
    (setq *files* (vla-get-Files (vla-get-Preferences (vlax-get-acad-object))))
     (vla-put-SupportPath *files* (strcat (vla-get-SupportPath *files*) ";C:\\Lisps\\Steel"))
    ; etc..
  5. #5
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,011
    You can load lisps on start up automatically using acaddoc.lsp so could check also for a menu if not loaded, or am I misunderstanding your question.
  6. #6
    Windows Xp sp3
    4 GB
    Viewsonic
    Surveying
    Surveying
    AutoCAD 2009
    May 2012
    Udupi,INDIA
    238
    runcad.txtruncad.txt
    Quote Originally Posted by BIGAL View Post
    Yes Correct Bigal , I have created a .bat file using this code
    Code:
    "C:\Program Files\Autodesk\AutoCAD 2012\acad.exe" %%V /b "C:\AutoCADscripts\ScriptName.scr"
    when I click the batch file AutoCAD Starts and and load the .scr file
    but it is giving error
    please help me
    runcad.txt
    Found this code in http://www.cadtutor.net/forum/showth...-to-run-script
    Ganesh Shetty
  7. #7
    Super Member
    not applicable
    Jun 2016
    606
    Try removing %%V.
    BricsCAD 18
  8. #8
    Windows Xp sp3
    4 GB
    Viewsonic
    Surveying
    Surveying
    AutoCAD 2009
    May 2012
    Udupi,INDIA
    238
    roy_043 thank you it is working now ...and how to load a lisp file from known directory with .scr file
    Ganesh Shetty
  9. #9
    Super Member
    not applicable
    Jun 2016
    606
    Code:
    (load "X:/MyPath/MyLisp.lsp")
    BricsCAD 18
  10. #10
    Windows Xp sp3
    4 GB
    Viewsonic
    Surveying
    Surveying
    AutoCAD 2009
    May 2012
    Udupi,INDIA
    238
    thank you roy
    Ganesh Shetty
  1. create batch file to run script ?
    By mostafa badran in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 8th Jan 2016, 05:38 pm
  2. File Copy Batch
    By suryatry26 in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 18th Oct 2012, 01:02 pm
  3. Batch file for changing file name
    By XCrossWindsX in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 1st Jan 2012, 08:07 am
  4. Using Batch Processing to create a *.dwg File List?
    By muck in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 29th Sep 2010, 06:07 pm
  5. plot to file (as a batch file)
    By tbui63 in forum AutoCAD General
    Last Post: 26th Apr 2006, 07:30 pm
