Results 1 to 2 of 2
    Junior Member
    AutoCAD 2010
    Aug 2015
    21
    Default Export point coordinates and its label to TXT
    Hi,
    I have a 3D point (X,Y,Z) and label. This point and label have the same 2D base point (Xp,Yp = Xl, Yl). And there is not a block. Is it possible to export point number and coordinates to text file (with space as separator)?
    I attached image with an example.
    Thanks for any assistance.
    Junior Member
    AutoCAD 2010
    Aug 2015
    21
    The topic is closed.
    The 'coorN.zip‎' file has everything I've asked above. The file works perfectly to this task! It can be found here:
    http://www.cadtutor.net/forum/showth...931#post258931
  1. export point coordinates
    By yjjyjy in forum AutoCAD Drawing Management & Output
    Last Post: 14th Jan 2014, 09:15 pm
  2. Lisp for placing excel-defined coordinates with label top of them
    By flausbert in forum AutoLISP, Visual LISP & DCL
    Last Post: 31st Mar 2012, 02:27 pm
  3. Label xy coordinates on the drawing
    By ali888 in forum AutoCAD General
    Last Post: 17th Jun 2011, 07:45 am
  4. Label coordinates on the layout
    By viriato79 in forum AutoCAD General
    Last Post: 3rd Sep 2008, 10:11 am
  5. export id, x, y, z and label points (survey upload)
    By angus absolute in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Jul 2008, 12:19 pm
Tags for this Thread
