+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
  1. #1
    Super Member prodromosm's Avatar
    Using
    AutoCAD 2014
    Join Date
    Jul 2010
    Posts
    610
    Default Help with a lisp
    Hi , I am using this lisp a lot of time. I am trying to change the insert text to annotated. The lisp create the annotate text style . The insert text is in the correct text style but is not annotated . Can any one help ???
    Code:
    (defun c:tEST (/ *error* varlist oldvars pt1 tval)
    (command "_.-style" "_KEIM" "arial.ttf" "_annotative" "_yes" "_no" 2.5 1.0 0.0 "_no" "_no" "_no")
        (defun *error* (msg)
        (mapcar 'setvar varlist oldvars)
        (if (= msg "")
            (princ "\nText Inserted.")
            (princ "\nEsc or Error Pressed...")
        ) ;_  end if
        ) ;_  end defun
        (setq varlist (list "CMDECHO" "CLAYER")
          oldvars (mapcar 'getvar varlist)
        ) ;_  end setq
        (while (and    (/= (setq pt1 (getpoint "\nSelect Insertion Point: ")) nil)
            (/= (setq tval (getstring t "\nSpecify Text: ")) "")
           ) ;_  end and
        (if (not (tblsearch "Layer" "TEXT"))
            (command "-layer" "m" "TEXT" "")
        ) ;_  end if
        (entmake (list '(0 . "TEXT")
                   '(8 . "TEXT")
                   (cons 10 pt1)
                  (cons 40 (getvar "TEXTSIZE"))
                   (cons 1 tval)
                   '(50 . 0.0)
                   '(7 . "_KEIM")
                   '(71 . 0)
                   '(72 . 0)
                   '(73 . 0)
             ) ;_  end list
        ) ;_  end entmake
        ) ;_  end while
        (*error* "")
    ) ;_  end defun
  2. #2
    Using
    AutoCAD 2014
    Join Date
    Jul 2010
    Posts
    610
    Default
    I dont know why the annotate is not working
  3. #3
    Senior Member
    Computer Details
    OMEGA-ThundeR's Computer Details
    Operating System:
    Windows 10
    Computer:
    HP Z440
    Discipline
    Civil
    OMEGA-ThundeR's Discipline Details
    Occupation
    Civil Engineer (CAD Design)
    Discipline
    Civil
    Using
    AutoCAD 2017
    Join Date
    Oct 2008
    Location
    Netherlands
    Posts
    320
    Default
    It's a crude solution, but it worked for me
    Code:
        ) ;_  end entmake
    (command "CHPROP" "last" "" "Annotative" "yes" "")
        ) ;_  end while
    Place that command line part in your code between the 'End entmake' en 'end while' and it should work.
    The command changes the properties of the last object, and since in this case it's a text you can change the annotative setting.
  4. #4
    Using
    AutoCAD 2014
    Join Date
    Jul 2010
    Posts
    610
    Default
    Hi OMEGA-ThundeR , thank you for the replay. I did the change and worked ,but i want the paper height to be 2.5 no t 2500 ? Any ideas?
    Code:
        (if (= msg "")
        ) ;_  end if
        ) ;_  end defun
        ) ;_  end setq
           ) ;_  end and
        ) ;_  end if
                   '(8 . "TEXT")
                   (cons 10 pt1)
                   (cons 1 tval)
                   '(50 . 0.0)
                   '(7 . "_KEIM")
                   '(71 . 0)
                   '(72 . 0)
                   '(73 . 0)
             ) ;_  end list
        ) ;_  end entmake
        ) ;_  end while
        (*error* "")
    ) ;_  end defun
  5. #5
    Senior Member
    Computer Details
    Operating System:
    Windows 10
    Computer:
    HP Z440
    Discipline
    Civil
    Occupation
    Discipline
    Civil
    Using
    AutoCAD 2017
    Join Date
    Oct 2008
    Location
    Netherlands
    Posts
    320
    Default
    I'm sorry, but can't help you with any 'annotative' based problems. I never use annotative texts.
    You might need to edit some settings within your SCALELISTEDIT though. Or perhaps you need to change the text height in the above code from 2.5 to 0.0025.
    Anyway, there seems to be a factor 1000 problem somewhere .
  6. #6
    Using
    AutoCAD 2014
    Join Date
    Jul 2010
    Posts
    610
    Default
    I told to the code that
    Code:
    so the paper space must be 2.5
    I can not understand
  7. #7
    Using
    AutoCAD 2014
    Join Date
    Jul 2010
    Posts
    610
    Default
    Thanks i find it
  8. #8
    Senior Member
    Computer Details
    Operating System:
    Windows 10
    Computer:
    HP Z440
    Discipline
    Civil
    Occupation
    Discipline
    Civil
    Using
    AutoCAD 2017
    Join Date
    Oct 2008
    Location
    Netherlands
    Posts
    320
    Default
    If there is any field of expertise i lack it's annotative scales. So i can't be of help on that field .
  9. #9
    Using
    AutoCAD 2014
    Join Date
    Jul 2010
    Posts
    610
    Default
    Is still not working properly.
    This is not the correct way to do this ...
    Code:
        ) ;_  end entmake
        ) ;_
  10. #10
    Senior Member
    Computer Details
    Operating System:
    Windows 10
    Computer:
    HP Z440
    Discipline
    Civil
    Occupation
    Discipline
    Civil
    Using
    AutoCAD 2017
    Join Date
    Oct 2008
    Location
    Netherlands
    Posts
    320
    Default
    Why not? It does what was asked right? Set the text object annotative?
    What is the problem? You need to change something else too?
Similar Threads
  1. Pause a lisp to interact with a dynamic block and then resume the lisp
    By woodman78 in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th May 2015, 10:38 am
  2. [LISP] First time writing LISP routine... trying to rotate, move and scale
    By chiimayred in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Jul 2013, 06:02 pm
  3. chk my new lisp & suggestion how to improve this lisp (intersecation cleane)
    By autolisp in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Sep 2010, 03:55 am
  4. Replies: 3
    Last Post: 10th Aug 2010, 04:39 am
  5. a lisp to apply 3 different lisp to 3 obj types filtered from one selection
    By gilsoto13 in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Nov 2009, 05:28 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
