Results 1 to 8 of 8
    Senior Member
    Civil
    Aftertouch's Discipline Details
    Civil
    Engineer
    AutoCAD 2017
    Jul 2016
    Netherlands
    258
    Default Build list without duplicates
    Hello all,
    I got a lot of layers that contain numbers. Example below:
    Code:
    B-OI-KL-DATA_KPN_0000546663_VECT_17O000770-G
    B-OI-KL-DATA_KPN_0000546663_VECT_17O000771-G
    B-OI-KL-DATA_KPN_0000546663_VECT_17O000772-G
    B-OI-KL-DATA_LIANDER_0000574962_VECT_17O000770-G
    B-OI-KL-DATA_LIANDER_0000574962_VECT_17O000771-G
    B-OI-KL-DATA_REGGEFIBER_0000579733_VECT_17O000772-G
    The numbers can be completely random, not pre-set.
    the total list can be up to 100 layers long.
    I can filter the number using:
    Code:
    		(vlax-for obj (vla-get-layers doc)
    		(setq lay (vla-get-name obj))
    		(setq meldingnr "none")
    		(setq meldingsoort "none")
    			(if (wcmatch (strcase lay) "B-OI-*")
    	 				(cond
    						((= meldingnr "none")
    						(setq meldingnr (strcat (substr lay (-(strlen lay) 10) 9 ))) ; get number from layer.
                             <do more stuff with all layers>
    This evaluates all layers and does something with it.
    How can i make a check, that if it gets a number that is not 'meldingnr' it adds it to the 'meldingnr'
    I am looking for a result that looks like:
    Code:
    meldingnr = 17O000770, 17O000771, 17O000772 (can get much longer)
    (princ meldingnr)
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2015
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,109
    One way with member function;
    Code:
    (member 170000771 '(170000771 170000772 170000773))
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,215
    Or vl-position, or just collect everything and use something from LM's unique & duplicate list functions.
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,011
    Not sure if this is what you want but there was a post here about missing number 1 3 4 5
    "2" is missing. Sorry no idea what its heading was.
  5. #5
    Senior Member
    Civil
    Civil
    Engineer
    AutoCAD 2017
    Jul 2016
    Netherlands
    258
    I am a bit closer already, i made this:
    Code:
    	(setq meldingnrlist '())
    	(setq meldingsoortlist '())
    	(setvar "CMDECHO" 0)
    						(if(=(member meldingnr meldingnrlist) nil)
      							(setq meldingnrlist (cons meldingnr meldingnrlist))
    					(setq meldingsoort (strcat (substr lay (-(strlen lay) 8) 1 )))
    						(if(= meldingsoort "O")
    							(setq meldingsoort "Oriƫntatieverzoek")
    							(setq meldingsoort "Graafmelding")
    						(if(=(member meldingsoort meldingsoortlist) nil)
      								(setq meldingsoortlist (cons meldingsoort meldingsoortlist))
    now i managed to get this:
    Code:
    !meldingnrlist = ("17O000770" "17O000771" "17O000772")
    !meldingsoortlst = ("O")
    Now i want the add this as a TEXT in the drawing...
    I tried:
    Code:
    (setq nummer (vl-princ-to-string meldingnrlist))
    (setq soort (vl-princ-to-string meldingsoortlist))
    But then it returns:
    Code:
    (17O000770 17O000771 17O000772)
    (Oriƫntatieverzoek)
    How can i let it look like:
    17O000770, 17O000771, 17O000772 (remove the "(" and ")" and add comma's???)
  6. #6
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,215
    Hint:
    Code:
    _$ (mapcar '(lambda (x) (strcat x ",")) '("17O000770" "17O000771" "17O000772"))
    ("17O000770," "17O000771," "17O000772,")
    _$ (apply 'strcat (mapcar '(lambda (x) (strcat x ",")) '("17O000770" "17O000771" "17O000772")))
    "17O000770,17O000771,17O000772,"
    _$ (vl-string-right-trim "," (apply 'strcat (mapcar '(lambda (x) (strcat x ",")) '("17O000770" "17O000771" "17O000772"))))
    "17O000770,17O000771,17O000772"
    _$
    BTW, Heres an example how to obtain that "meldingnrlist":
    Code:
    (defun GetMeldingnrlist ( / LM:str->lst LayerDef Layers meldingnrlist )
      ;; String to List  -  Lee Mac
      ;; Separates a string using a given delimiter
      ;; str - [str] String to process
      ;; del - [str] Delimiter by which to separate the string
      ;; Returns: [lst] List of strings
      (defun LM:str->lst ( str del / pos )
        (if (setq pos (vl-string-search del str))
          (cons (substr str 1 pos) (LM:str->lst (substr str (+ pos 1 (strlen del))) del))
          (list str)
      (while (setq LayerDef (tblnext "LAYER" (not LayerDef)))
        (setq Layers (cons (cdr (assoc 2 LayerDef)) Layers))
      (if (setq Layers (vl-remove-if-not '(lambda (x) (wcmatch x "B`-OI`-KL`-DATA_*_*_*_*`-G")) Layers))
        (setq meldingnrlist
            (apply 'strcat
              (mapcar '(lambda (x) (strcat (vl-string-right-trim "-G" (last (LM:str->lst x "_"))) ","))
                Layers
    (GetMeldingnrlist)
  7. #7
    Senior Member
    Civil
    Civil
    Engineer
    AutoCAD 2017
    Jul 2016
    Netherlands
    258
    Thanks all,
    I got it working the way i want.
    The final code: (fragments)
    Code:
    	(setq meldingnrlist '()) ;Empty list
    	(setq meldingsoortlist '()) ; empty list
    (if (wcmatch (strcase lay) "B-OI-*") ; check for layer name starting with...
    					(setq meldingnr (strcat (substr lay (-(strlen lay) 10) 9 ))) ; get the meldingnr.
    						(if(=(member meldingnr meldingnrlist) nil); if the number is not in the list..
      							(setq meldingnrlist (cons meldingnr meldingnrlist)); add it to the list...
    								(setq meldingsoort (strcat (substr lay (-(strlen lay) 8) 1 ))) ; add other info of that layer to other list.
    								(if(= meldingsoort "O") ; change some names
    (setq meldingnrlist (vl-string-right-trim ", " (apply 'strcat (mapcar '(lambda (x) (strcat x ", ")) meldingnrlist)))) ; add comma's an remove last comma
    (setq meldingnrlist (vl-princ-to-string meldingnrlist)) ; make string of the result.
    (Result is one string with all elements of the lisp, seperated with a comma.) :-)
  8. #8
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,215
    You don't need this:
    Code:
    Because this is already a string:
    Code:
  1. New Autodesk Memento Oct 2015 Build (Windows version, build 1.5.0.30)
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 4th Nov 2015, 07:30 am
  2. removing duplicates in a list
    By Lt Dan's legs in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Sep 2010, 07:24 pm
  3. Plotting Duplicates, but don't want it to!
    By SplashMan in forum AutoCAD Drawing Management & Output
    Last Post: 9th Nov 2009, 04:16 pm
  4. Please help. Erasing duplicates.
    By Jacko93 in forum AutoCAD General
    Last Post: 15th May 2009, 02:27 pm
  5. Delete Duplicates
    By CAD-e-Corner in forum AutoCAD RSS Feeds
    Last Post: 7th Dec 2007, 07:41 am
