Results 1 to 2 of 2
    Full Member GISdude's Avatar
    Electrical
    GISdude's Discipline Details
    Substation Drafter
    Electrical
    Civil 3D 2012
    Jun 2012
    Sac, CA
    39
    Default plotting in modelspace - cuts off part of drawing (only in some drawings)
    HI all,
    I'm trying to plot in model space and the printer is cutting off part of the drawing. I choose plot-->extents --> center the plot --> fit to paper. The x coord is always 0, however the y coord is always at .09280. I've tried adjusting the y to 0, and unchecking the plot, but the cutoff always happens. Keep in mind, this is in a handful of drawings. I've plotted to a different plotter (XEROX) and it works perfectly fine. I've switched the PLOTOFFSET variable and it makes the problem worse.
    My fear is this is a driver issue, Canon doesn't support this plotter anymore.
    Many thanks for any help.
    autocad map3d 2012, win7.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,717
    It sounds like hard clip limits you need to check the settings for the two different printers. If you have a outside border rectang and end up with a "L" thats clip limits. Put a "point" about .05 away from bottom left and top right pick those two points using window and fit, it should work now.
  1. Batch Plotting Drawings Without Having to Open Every Drawing
    By Vincent_ in forum AutoCAD Drawing Management & Output
    Last Post: 5th Feb 2013, 03:15 am
  2. drawing doesn't appear in Modelspace
    By engamcmu in forum AutoCAD Beginners' Area
    Last Post: 7th Sep 2012, 03:40 pm
  3. PUBLISH cuts off random drawings
    By Krztoff in forum AutoCAD Drawing Management & Output
    Last Post: 9th Jul 2010, 02:26 pm
  4. Printer cuts off each end of drawing
    By Philster in forum AutoCAD Drawing Management & Output
    Last Post: 28th Oct 2009, 03:07 pm
  5. Plotting all ModelSpace views..
    By hardwired in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Jul 2008, 12:25 pm
Tags for this Thread
