gegenytibor Posted January 11, 2017 Share Posted January 11, 2017 Hi all, I have 4 dynamic blocks and each has 4 different visibility states. I would like to create a dynamic block which contains the previous 4 dynamic blocks and where I can set the different blocks different visibility states (like the drop down menu). Is it possible somehow? Or should I make all of the possibilities visibility states? Please help if you can! Thank you! Quote Link to comment Share on other sites More sharing options...
dirkvandonkelaar Posted April 7, 2017 Share Posted April 7, 2017 From what I can see, making 16 visibilities in a block with each single visibility in the nested block should work. Maybe it can be done easier, but this is the workaround I always use. Quote Link to comment Share on other sites More sharing options...
iconeo Posted April 7, 2017 Share Posted April 7, 2017 What you want is only possible with vis-add-eng lisp files (and AutoCAD 2007?). I would just follow dirks recommendation for simplicity sake. Quote Link to comment Share on other sites More sharing options...
