Page 1 of 2 1 2 LastLast
Results 1 to 10 of 20
    Junior Member
    not specified
    Oct 2004
    12
    Default Change line thickness
    Hi all,
    Does anyone know how I would change both the model and paper space thickness of a line in AutoCAD 2004? I've tried changing "line thickness" and "line weight" in the properties dialog box but it doesn't seem to matter whether it's 0 or 9,999,999 or any number, it just looks the same, in both the model space and paper space views.
    I have a drawing someone else did that uses polylines of different thickness so I have tried to figure out how they did it. Again, looking at the properties dialog box it seems to make no difference what I set the "line thickness" or "line weight" properties to...the line just stays the same size regardless.
    I want to change line thicknesses because I'm designing a surface water pipe layout...I want the pipes to be a lot thicker than the lines that represent the actual building so that they will stand out when I plot the drawing.
    Any ideas?
    Thanks
    -Rob
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    8GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    In a nutshell, I create 3D models from the client's CAD files or design sketches, which I then use to produce high quality rendered images. Click on the link in my signature to view my portfolio. I'm always looking for work, so let me know if you need any renders. :)
    3ds Max 2011
    Feb 2006
    Southern California
    8,429
    Default Lineweight Settings
    Go to your Format pull down menu and select Lineweight. This will open the Lineweight Settings dialog. Check the box that says "Display Lineweight". Once you hit Ok, you should see all your line thicknesses.
    Junior Member
    not specified
    Oct 2004
    12
    Ahhhh I see. Simple when you know how.
    Many thanks for that.
    -Rob
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,495
    i still say use Polylines and use widths. makes the "thickness" stay constant.
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
  5. #5
    Junior Member
    not specified
    Oct 2004
    12
    Mmm, got another issue now. Got the line thickness sorted out but I have given my drainage pipes (lines) a dashed linetype to further distinguish them from the other on-site infrastructure.
    Problem is when I go to Paper Space, the lines are just continuous....what happened to my dashed settings??? I can see them in model space but they do not seem to apply to paper space?
    Thanks
    -Rob
  6. #6
    Multi-disciplinary
    Multi-disciplinary
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,495
    change your LTSCALE.
  7. #7
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Ltscale=1
    Psltscale=1
  8. #8
    Senior Member
    AutoCAD 2008
    Aug 2006
    Northern Ireland ( Norn Iron )
    134
    Smile Fat lines
    To further clarify.
    Fat lines are achieved by setting the line weights in the Layer Properties Manager, for printing purposes or adjusting wot you see on screen by ticking the Lineweight Settings dialog box as explained previously.
    Personaly I don’t switch this on as I like to see sharp corners and fat lines get in the way of other close objects on screen. I know where my fat lines are!
    (all round my waist unfortunately)LOL LOL
    However, the thickness refered to in the properties dialog box is a 3D value where the line is given a vertically extruded height value.
    Not to be confused with a width which is horizontal!
    To get really broad lines use a polyline with a width value as StykeFace suggests.
    See ‘Pedit’ and the various options (w).
    Stephen
  9. #9
    Full Member
    AutoCAD 2012
    Jan 2006
    England
    94
    As we tend to work almost exclusively in 2D model space (scaling up text/ dims/drawing frames) I've always used plot configuration files to control plotted line thicknesses related to the line's screen colour, using ratioed thicknesses (based on the old Rotring pen sizes) for differing plotted drawing sizes. That way the line thicknesses always look right in proportion to the size of the printed drawing, in the same way as enlarging or reducing on a photocopier. We also get our logos to print in colour so it's easy to differentiate the master from a print.
    After a while you can visualise the plotted thickness from the colour, though it usually takes at least one plot and adjustments to get the finished drawing just right.
    The trouble with polylines is I've never discovered how to draw circles, arcs, elipses etc easilly. and to avoid objectionable end connections looking like a draughtsman who couldn't quite be bothered.
    What are the advantages and disadvantages of using plot configuration files to control thickness in this way?
    Boro Nut
  10. #10
    Junior Member
    not specified
    Oct 2004
    12
    Thanks for the replies. Much appreciated.
    -Rob
  1. changing line thickness
    By mutant_kittykat in forum SketchUp
    Last Post: 5th Sep 2006, 07:44 pm
  2. Line thickness when printing
    By adouraghy in forum AutoCAD General
    Last Post: 8th May 2006, 05:25 am
  3. break layer and line thickness
    By sharlon in forum AutoCAD General
    Last Post: 25th Mar 2006, 02:23 pm
  4. line thickness/scale/weight
    By maack in forum AutoCAD Beginners' Area
    Last Post: 18th Apr 2005, 06:55 am
  5. line thickness
    By rlowe90 in forum AutoCAD Beginners' Area
    Last Post: 5th Sep 2004, 10:28 am
