Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
  1. #11
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,140
    Quote Originally Posted by Boro Nut View Post
    As we tend to work almost exclusively in 2D model space (scaling up text/ dims/drawing frames) I've always used plot configuration files to control plotted line thicknesses related to the line's screen colour, using ratioed thicknesses (based on the old Rotring pen sizes) for differing plotted drawing sizes. That way the line thicknesses always look right in proportion to the size of the printed drawing, in the same way as enlarging or reducing on a photocopier. We also get our logos to print in colour so it's easy to differentiate the master from a print.
    After a while you can visualise the plotted thickness from the colour, though it usually takes at least one plot and adjustments to get the finished drawing just right.
    The trouble with polylines is I've never discovered how to draw circles, arcs, elipses etc easilly. and to avoid objectionable end connections looking like a draughtsman who couldn't quite be bothered.
    What are the advantages and disadvantages of using plot configuration files to control thickness in this way?
    Boro Nut
    that's what we use in our offices. i know how "thick" the line is, i don't need it thick on my screen.
    as far as Polylines go, i just use this method for certain blocks or objects that i want "bolded" on my prints, to further distinguish things on my screen, and on the print. as for arcs, circles, etc, just PEDIT and join. i don't do it often so it doesn't bother me really.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  2. #12
    Full Member Ivan006's Avatar
    Ivan006's Computer Details
    Windows 7
    Mechanical
    Ivan006's Discipline Details
    CAD Operator
    Mechanical
    AutoCAD 2010
    Oct 2009
    37
    I have a question: I know each color has it's own thickness, for example, cyan shows up really thick when printed in color or black and white. Is there a way to change the thickness of a color so that it has the same thickness of another color. For example I want to have the color 250 printed for my Arch. background, but I want the thickness of color 253. Is there a way to see the color definition and modify to suit other color thickness'?
    Hope my question is clear.
  3. #13
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    It shouldn't matter what color the line is as far as how "thick" it plots. I can draw ten lines, assign them each a different color and have all ten plot exactly the same. Did you check your Layer Properties Manager? Maybe the layer your line is on has a lineweight assigned to it other than "Default".
  4. #14
    Windows 7
    Mechanical
    CAD Operator
    Mechanical
    AutoCAD 2010
    Oct 2009
    37
    Maybe I wasn't as clear as I should have been.
    When I plot a line drawn in 250 and one in 253 in their default setting, you can see the color and thickness difference. How would I find out what the default thickness is on color 253 to make it the same on 250? I guess I'll just play with the thickness settings of the 250 line until I get it the same.
    Thanks.
  5. #15
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    Maybe you are using the wrong terminology to describe what you are seeing? I don't see how lineweight is affected by the color one assigns to it. By lineweight I mean whether a line plots thin or thick like the difference between a 3mm or a 9mm line.
    Would you happen to be referring to how light or dark a line appears when printed and not the actual width or thickness?
  6. #16
    Windows 7
    Mechanical
    CAD Operator
    Mechanical
    AutoCAD 2010
    Oct 2009
    37
    Doesn't the lineweight and color affect the light or darkness of the print? I thought that if I change the color of a line, it would determine whether or not the print will come out light or dark. If I change the thickness of the layer, doesn't it just override the default color thickness? Basically, I want to see the color in CAD as 250, but print it out in 253 darkness.
  7. #17
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    Lineweight affects how thin or thick the line plots. I thought I made that clear. You can assign line weights that could be as thin as 1mm or 1 meter if you wanted to.
    Color does not play a role in how thin or thick a line plots unless you want it to. It is completely arbitrary. You may decide that the lighter the color the thinner the line will be and the darker the color the thicker the line will be. Make a chart with two columns. In the left column put the lineweight and in the right column assign it a color. Now use this chart when you assign colors to your layers in the Layer Properties Manager.
    You may even want to include a column in your chart for your layer names too. Example:
    Layer name: Existing
    Color: White
    Lineweight: .009
  8. #18
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    Lineweight can be set by color in your plotstyles. This can be viewed in a paperspace with "Show Plot Styles" Checked.
  9. #19
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    Quote Originally Posted by Ivan006 View Post
    For simplicity sake start the print/plot command, look to the upper right for the plot style table, there is an icon further to the right, pick that to edit the current plot style. Yours will no doubt end in .ctb. You will be in the plot style table editor, move down to the 253 plotstyle, note the lineweight, now move to 250, change the lineweight to match.
    If you don't have the plot style table showing in the upper right look to the lower right for an arrow in a circle, pick that to expand the dialog box.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  10. #20
    Windows 7
    Mechanical
    CAD Operator
    Mechanical
    AutoCAD 2010
    Oct 2009
    37
    Quote Originally Posted by rkent View Post
    Thanks.
    I found out that what I was trying to do is see one color on the CAD screen, but "Screen" the color as something else when it prints, not change the lineweight. I should have went to the Plot Style Table Editor sooner.
    Sorry everybody.
  1. changing line thickness
    By mutant_kittykat in forum SketchUp
    Last Post: 20th Apr 2016, 02:00 pm
  2. Line thickness when printing
    By adouraghy in forum AutoCAD General
    Last Post: 8th May 2006, 05:25 am
  3. break layer and line thickness
    By sharlon in forum AutoCAD General
    Last Post: 25th Mar 2006, 02:23 pm
  4. line thickness/scale/weight
    By maack in forum AutoCAD Beginners' Area
    Last Post: 18th Apr 2005, 06:55 am
  5. line thickness
    By rlowe90 in forum AutoCAD Beginners' Area
    Last Post: 5th Sep 2004, 10:28 am
