Using Command SELECT with ssget
SunnyTurtle
Hello everyone.
I am having a mental blank as i am sure i know the solution to this but cannot remember
I am trying to have a shortcut to select all xrefs starting with X*
I have tried this but i does not work.
(defun c:xrss ()
(command "SELECT"
(ssget "X" (list
(cons 0 "INSERT")
(cons 2 "X*")
However this does work
(defun c:xrerase ()
(command "erase"
(ssget "X" (list
(cons 0 "INSERT")
(cons 2 "X*")
Can anyone explain what is happening here. I don't need a quick fix but would like to understand the process
The
(ssget "X" (list(cons 0 "INSERT")(cons 2 "X*"))
part creates the selection set, what are you trying to do with "SELECT"?
Try
(sssetfirst nil(ssget "X" (list(cons 0 "INSERT")(cons 2 "X*")))
  • 1 month later...
Thank tombu
I was unaware of the function.
To make sure I understand correctly "sssetfirst" used to instruct autocad to grip something?
(sssetfirst gripset [pickset])
gripset is redundant and is always nil
pickset is a selection set you want to grip (select to autocad user)
Thank tombu
In r14 (not 2014) early days of grips objects gripped were a gripset and objects selected were a pickset. After that they simplified it the way it is now. So as little as possible code would have to be rewritten we now use nil instead of gripset.
