Results 1 to 4 of 4
    Junior Member
    eyal's Computer Details
    WINDOWS 10
    Civil
    AutoCAD 2016
    Jan 2017
    20
    Default how to migrate custom toolbar with macro from autocad 2016 to autocad 2017
    Hi everyone,
    I made a custom icons with macros that loads lisps,
    how to migrate them from autocad 2016 to autocad 2017?
    it is very important , I don't want to make the icons again evry time I change my autocad.
    Thank you
    Eyal
    Senior Member
    Civil
    Aftertouch's Discipline Details
    Civil
    Engineer
    AutoCAD 2017
    Jul 2016
    Netherlands
    302
    Transfer your ribbon from the active cuix to the new one. (Workspace customization)
    Junior Member
    WINDOWS 10
    Civil
    AutoCAD 2016
    Jan 2017
    20
    Hi Aftertouch,
    I am a newbe,(new user),please could you explain how should I transfer my custom icons with macros,
    I made a new toolbar with custom icons, I add load command to my acad2017doc.lsp that loads the lisp automatically , and when i click my custom icons they enter the command of the lisp so I can use it.
    if I want to migrate only my custom toolbars , how should I do it? I don't think it has to be connected with the ribbon , because I use the classic workspace.
    Thank you
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,702
    How did you make the Toolbars ? All my toolbars and menus are seperate from the normal acad mnu/cuix etc. I just use menuload to add a partial menu. My icons are saved in a directory which is set via CONFIG, Files,Customization files,icons
    Did you use the cui and added to the default menu ?
  1. AutoCAD 2017 Custom A360 Sync?
    By tzframpton in forum CAD Management
    Last Post: 19th Dec 2016, 12:19 am
  2. Replies: 2
    Last Post: 16th May 2016, 04:13 am
  3. Will Migrate Custom Settings from vanilla AutoCAD work?
    By dallion in forum Vertical Products: General
    Last Post: 2nd Apr 2013, 02:52 pm
  4. Custom toolbar and purge macro
    By mshearer in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Jan 2009, 08:25 pm
  5. How to run a VBA macro from a custom toolbar button?
    By NigelFinch1 in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th Jun 2006, 07:56 pm
