+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
  1. #1
    Forum Newbie
    Using
    AutoCAD 2002
    Join Date
    Nov 2006
    Posts
    7
    Default Some Very Beginner Questions-Scale and Line Type
    Hi there,
    I actually took an intro CAD class my freshman year 4 years ago, but haven't used it since. Now I'm back at it, and I'm creating a pretty simply drawing, but I'm having some trouble. I chose ISO A0 color dependent for my layout, and when I begin laying out my design according to the dimensions (they're all inches), it's extremely small. So obviously scrolling inward with teh scroll wheel on my mouse fixes that problem, but when I go into the title block mode the drawing is insanely small. I don't see what I'm doing wrong here. I remember when I designed things in my class they always showed up fine on the title block view. For instance I want one of my lines to be 5 inches in length so I click a point, type in 5 and hit enter and the line appears to small until I zoom in.
    Also, I defined the various hidden lines, center lines, visible lines, etc in my layers, and even loaded the proper line type for each, but when I draw them the hidden lines, center lines, etc don't show up. They're just a solid line with the color I gave the layer. What gives? Thanks for any help in advance. Btw, I'm using AutoCAD 2002.
  2. #2
    Luminous Being StykFacE's Avatar
    Computer Details
    StykFacE's Computer Details
    Operating System:
    Windows 7 Ultimate 64bit
    Computer:
    Dell Precision T3500
    Discipline
    Multi-disciplinary
    StykFacE's Discipline Details
    Occupation
    BIM Manager & Design Specialist
    Discipline
    Multi-disciplinary
    Details
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Using
    Revit 2013
    Join Date
    Mar 2006
    Location
    Dallas, TX - USA
    Posts
    6,586
    Default
    change your LTSCALE. you can set it to however you need. just remember this.... if you set your LTSCALE to 1, then that's one repetition of the Linetype per one unit of the drawing. 0.5 is two repititions, and 2 is half a repetition. keep that in mind when setting the LTSCALE. another way is to zoom in on the object, and REGEN the drawing. if you see the linetype show up, then that's the problem.
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
  3. #3
    Forum Newbie
    Using
    AutoCAD 2002
    Join Date
    Nov 2006
    Posts
    7
    Default
    Yeah I tried setting it at various settings and tried the regen, but it's simply not working. I have my units set to inches as well so I'm not sure if that has anything to do with it. Maybe it would be easier to post the drawing.
  4. #4
    Forum Newbie
    Using
    AutoCAD 2002
    Join Date
    Nov 2006
    Posts
    7
    Default
    I attached the file if anyone wants to look at it.
  5. #5
    Forum Newbie
    Using
    AutoCAD 2002
    Join Date
    Nov 2006
    Posts
    7
    Default
    Yeah something is screwy with my scale because when I apply the dimensions, they are correct but absolutly huge in size.
  6. #6
    Forum Newbie
    Using
    AutoCAD 2002
    Join Date
    Nov 2006
    Posts
    7
    Default
    Ok I've got the line scale type thing figured out. However, why is my drawing still showing up super small on the paper view?
  7. #7
    Computer Details
    Operating System:
    Computer:
    Discipline
    Multi-disciplinary
    Occupation
    Discipline
    Multi-disciplinary
    Details
    Using
    Revit 2013
    Join Date
    Mar 2006
    Location
    Dallas, TX - USA
    Posts
    6,586
    Default
    Quote Originally Posted by Toyo4x4 View Post
    adjust your PSLTSCALE. remember when switching to Paperspace, the units change.
    this is a good rule of thumb: LTSCALE=1, PSLTSCALE=1. search these two variables in Help to read up on descriptions on how it works together.
  8. #8
    Forum Newbie
    Using
    AutoCAD 2002
    Join Date
    Nov 2006
    Posts
    7
    Default
    Thanks, the ltscale got my dimensions in order, but assigning psltscale to 1 doesn't change the size problem, should it be adjusted to something else? My dimensions are also still huge (in size...they're acurate, but just physically larger than the rest of my drawing).
  9. #9
    Computer Details
    Operating System:
    Computer:
    Discipline
    Multi-disciplinary
    Occupation
    Discipline
    Multi-disciplinary
    Details
    Using
    Revit 2013
    Join Date
    Mar 2006
    Location
    Dallas, TX - USA
    Posts
    6,586
    Default
    well all PSLTSCALE does is make all linetypes in paperspace the same, no matter how many scaled viewports you have. it's just the way it is... the units change when you go from Model Space to Layout Space. best way to do it, set up the LTSCALE to paperspace, and live with it in modelspace.
    now, dimensions are a different story. you kinda have to plan ahead. look at this thread i started awhile back to get your dimensions in order.... on the second page, post #14 i show you how to set it up.
    http://www.cadtutor.net/forum/showthread.php?t=8543
  10. #10
    Forum Newbie
    Using
    AutoCAD 2002
    Join Date
    Nov 2006
    Posts
    7
    Default
    Wow thanks, the dimstyle really helped...it's starting to come back to me now. However, if you get the chance, could you look at the file I attached and see what I mean about how small the drawing is in paper space? I'm still just kind of confused by that.
Similar Threads
  1. line type scale
    By nelsonrocha47 in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Dec 2006, 01:34 am
  2. another line type
    By GTizzle in forum AutoCAD Drawing Management & Output
    Last Post: 26th Jul 2006, 11:42 pm
  3. LINE END TYPE
    By chrisdarmanin in forum AutoCAD Drawing Management & Output
    Last Post: 6th Mar 2006, 07:20 pm
  4. line type scale....
    By boognish in forum AutoCAD General
    Last Post: 9th Dec 2005, 10:13 am
  5. some beginner questions
    By amateur in forum AutoCAD Beginners' Area
    Last Post: 2nd Jun 2005, 09:22 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
