Replace old template with new one but keep infromation
Hello all,
Im new here and learned alot from you guys. Now i have a problem that i couldnt find an answer to.
I have one drawing template/ block with attributes.
I want to insert my own templete/block but still use the attributes from the old one.
This will be done at multiple drawings at once.
I have tried the "extract Data" function but are unable to insert the information back again (multiple drawings)
And the best option would be to insert the templete/block and the info without opening the drawings sepretely.
If this cant be done in autocad, is there any other software available? :)
See attatchment with 3 exmaples in one drawing. Note that the drawing templates are seperatly normaly
BR Johan
EXEMPEL template move.dwg
Since your attribute tags are changed, i think this'll be hard with just AutoCAD...
I'd write a custom LISP for this one, wich extracts all attributes from the old block and then places it in the new block.
You could also do a check, so when you open the drawing, it instantly checks if a block with the old name exists, and replaces it for the new one.
