Auto dimension BOX need help with lisp
plecs
You need to use UCS and set the plane for each dimension. You can work out 3pts that represent the block faces and use the UCS 3 option or X & Z rotating 90 degrees.
Look at image and you can see the ucsicon is twisted so to enable the vertical dim to be in the plane.
ok I understand the idea, but I insert blocks in top plan with XYZ, but how do you save that change UCS UCS top XYZ coordinates change. then you have to instead make the front and dimension.
But there is another aspect when the exchange UCS what about the origin.
when you insert top insert block the origin of UCS exchange board in front origin if such do with it because you have to bring dimension where the block is not anywhere I do not know how to do that
