Results 1 to 3 of 3
    Forum Newbie ThingsNStuff's Avatar
    AutoCAD 2016
    Jan 2017
    Norway
    5
    Unhappy Is it possible and if so how to add views of the different state of objects?
    Hello, dear CADers
    this is my first post, so please don't rip my head off.
    I may lack the vocabulary to describe things the right way, but I will try.
    So I am making a drawing of a sliding door in 3D. Threre are two parts and they are of exactly same shape.
    I need to represent it from the front (half closed, and completely closed) and from the top (half closed, and completely closed).
    I know a bit about the viewports, but my questions is a bit more detailed.
    Is it possible (and if so how) to represent the door from views on the same page*?
    Do I just create two separate doors ( one open and one shut) and then change the layers so that one would be on f.e. CLOSED DOOR layer and the other one would be on the OPEN DOOR layer(and then block representation of the ones that I don't want in the viewport?)
    I hope that my question is clear enough.
    I attach a pdf of how I have it now.
    13JAN slider 927.pdf
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    694
    Hi there and welcome here.
    There are a lot of techniques that can be learned and used.
    But to make it easier for you as honest beginner i would recoment you just draw it 'twice'
    Make a good drawing from the shut version, then copy it (ortho, f8, on) with a FIXED distance to the left or right (lets say 5 m or so. Why fixed? To keep a good relation between the two so you can copy to/from.. After that you can try to use the sliding part as block and the fixt part as block.. DOOOO .. Homer ;-)
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
    AutoCAD 2016
    Jan 2017
    Norway
    5
    thank you, halam
  1. No objects visible in model space/3d views
    By PACKRAT69 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 6th Mar 2016, 01:28 pm
  2. No objects in Model space, But View ports has dwg views
    By RRS1987 in forum AutoCAD Drawing Management & Output
    Last Post: 4th Aug 2015, 01:48 pm
  3. objects off in layer state, still displays.
    By erin0karr in forum AutoCAD Drawing Management & Output
    Last Post: 5th Jul 2013, 04:18 pm
  4. Replies: 2
    Last Post: 13th Jul 2010, 05:38 pm
  5. SSM sheet views and model views
    By chelsea1307 in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Dec 2008, 09:37 am
Tags for this Thread
