Results 1 to 5 of 5
    Junior Member
    Architectural
    AutoCAD 2017
    Jan 2017
    18
    Default Page Setup Manager
    My computer was struck by lightning, so I've had to start from scratch. I have a question about page setup manager: on my previous computer I had windows 7, with cutepdf writer. I had set the default printer to cutepft writer on most of my drawings, but the new version of cutepdf writer doesn't seem to work on windows 10 - it does not give me an option of saving the file. This means I will have to replace it with the DWG To PDF.pc3. Which is not a problem, I will just change the plotter in my template, but I have several projects where I need to produce As Built drawings, and these run into hundreds of drawings of which I need to make pdf files.
    Has anyone else come across this problem with the cutepdf writer, and is there a solution to it?
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,131
    I use DWG TrueView in Wndows 10 and downloaded the latest version of CutePDF, and it works perfectly, allowing to Save As.
    I prefer the DWG to PDF plotter because it includes the layer information and allows direct measuring in the PDF when opened with Acrobat Reader DC.
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    There are ways to use a different plotter than the one assigned in your page set-up, especially if you use publisher.
    Drafting is a breeze.
    Junior Member
    Architectural
    AutoCAD 2017
    Jan 2017
    18
    I agree about the dwg to pdf - I also prefer it. But I found that I had a problem with some paper sizes, dwg to pdf didn't pick them up properly. It seems to be resolved in 2017, but I'm still stuck with hundreds of drawings with the old cutepfd writer.
    I will try downloading another version of cutepdf and see if that helps. In future, when I set up drawings I will use the dwg to pdf.
  5. #5
    Junior Member
    Architectural
    AutoCAD 2017
    Jan 2017
    18
    Thank you eldon - I removed the last cuteftp writer and reinstalled it, and it is now working properly.
  1. page setup manager
    By zera in forum AutoCAD Drawing Management & Output
    Last Post: 21st Jan 2010, 07:28 pm
  2. Page SetUp Manager
    By bigr1822 in forum AutoCAD General
    Last Post: 27th Jan 2009, 05:52 pm
  3. Page Setup Manager
    By yoshi in forum AutoCAD Beginners' Area
    Last Post: 2nd Dec 2008, 09:19 pm
  4. page setup manager
    By nicnicman in forum AutoCAD General
    Last Post: 6th Oct 2008, 09:41 am
  5. Page Setup Manager
    By GIB39 in forum AutoCAD Beginners' Area
    Last Post: 28th Sep 2007, 09:02 am
