Results 1 to 5 of 5
    Forum Newbie ThingsNStuff's Avatar
    AutoCAD 2016
    Jan 2017
    Norway
    5
    Question Most of the drawing not showing up when plotting
    Hello CADers!
    Today I have came upon this problem:
    I'm trying to export my drawing into PDF, but when I press on the preview, I see that most of the drawing is not represented.
    the layers are not frozen or turned off.
    any ideas?
    also, it looks like i somehow screwed up my monochrome.cdb file. could I download a new one from somewhere?
    thank you for your time
    Senior Member gS7's Avatar
    gS7's Computer Details
    Windows Xp sp3
    4 GB
    Viewsonic
    Surveying
    gS7's Discipline Details
    Drafts man / Surveyor
    Surveying
    AutoCAD 2009
    May 2012
    Udupi,INDIA
    238
    check the layer status are plottable or not
    Ganesh Shetty
    Windows Xp sp3
    4 GB
    Viewsonic
    Surveying
    Surveying
    AutoCAD 2009
    May 2012
    Udupi,INDIA
    238
    and try this link
    http://www.cadtutor.net/forum/showth...s-not-plotting
    Sent from my SM-E700H using Tapatalk
    Ganesh Shetty
    Senior Member
    OMEGA-ThundeR's Computer Details
    Windows 10
    HP Z440
    Civil
    OMEGA-ThundeR's Discipline Details
    Civil Engineer (CAD Design)
    Civil
    AutoCAD 2017
    Oct 2008
    Netherlands
    322
    Since i also notice a colorchange you might have setup a CTB or other plotstyle setup. You might have set the brown/yellow-ish color to print white/255/255,255,255. But check the layermanager to see if any layers are on a non-plotable setting.
  5. #5
    AutoCAD 2016
    Jan 2017
    Norway
    5
    Thank you for reply.
    I fixed it the following way: copied the object in model space, deleted the original and then the new one showed up just fine.
    any ideas what that could have been? seems like a glitch of the software to me.
  1. raster images not showing when plotting dwg to pdf
    By dannysteel in forum AutoCAD Drawing Management & Output
    Last Post: 21st Jan 2016, 03:55 pm
  2. Plotting to PDF- stopping PDF layers from showing/ plotting
    By MAREBER in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Aug 2015, 04:47 am
  3. Plotting with all black - Grey not showing!!
    By Ytsephill in forum AutoCAD General
    Last Post: 6th Apr 2010, 12:18 am
  4. CTB Files not showing as option for plotting
    By superhappyfunball in forum AutoCAD General
    Last Post: 10th Jul 2009, 11:57 pm
  5. Hidden objects showing when plotting
    By Edgar in forum AutoCAD General
    Last Post: 7th Oct 2008, 11:28 am
Tags for this Thread
