Results 1 to 3 of 3
    Forum Newbie
    AutoCAD 2010
    Dec 2011
    5
    Default Revit Keyboard Shortcuts
    Hi,
    I am using Revit 2016 & have set some keyboard shortcuts for commands. what i would really like to do is set a keyboard shortcut for "flip section" & "go to view". can any of the revit gurus shed some light on how to achieve this as the commands do not appear when i search in custom keyboard interface.
    Thanks in advance.
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,096
    Since it's not available in the list I'm not sure that it's possible with an out-of-the-box solution. Is it too much trouble to select or right-click and choose the Flip control, as well as double-clicking the Callout Head to activate the View? I'm all about reducing keystrokes, but not sure this is a real time saver in the end.
    I wonder if Dynamo could be used to create something for you on this. You may want to check out the programming forums over at the Dynamo forum:
    http://dynamobim.com/
    -TZ
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    683
    Not possible and Dynamo won't help since this is about DATA manipulation and does nothing with user interface..
    Put in a wish for more options on keyboard support. I will support it.
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
  1. Why cant revit keyboard shortcuts be the same as AutoCAD?
    By addesigns in forum Revit General
    Last Post: 8th Mar 2013, 09:10 pm
  2. Keyboard shortcuts gone
    By hepimen in forum AutoCAD Drawing Management & Output
    Last Post: 14th Apr 2008, 04:33 pm
  3. Keyboard shortcuts
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 1st Mar 2008, 02:11 am
  4. Keyboard shortcuts
    Last Post: 29th Feb 2008, 01:51 am
  5. Keyboard shortcuts
    By Lakeland in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Jan 2008, 01:03 pm
