Results 1 to 10 of 10
    Forum Newbie
    Electrical
    AutoCAD 2017
    Jan 2017
    8
    Default VBA CODE-From multiple areas to plot in model space to create a layout for each areas
    Hi everybody,
    I have a big problem....
    I have about 100 DWG with a lot of sheet in the same model space and i must print every sheet, so i am looking for a script in VBA or lisp to create from multiple areas to plot in model space, a layout tab for each area vba autocad.
    I found a lisp script, but it doesn't run (plotDWGarr).
    (http://www.cadforum.cz/cadforum_en/p...rawing-tip7585)
    Do you know another similar script o to write a VBA to do it?
    Thank you very much in advance
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,601
    If I understand correct this will plot all sheets in model space rather than trying to redo all of them.
    Code:
    ; plot multi title block in Model space
    ; By Alan H 2013
     (PROMPT ".....PRINTING DRAWING TO plotter....")
    (setq oldsnap (getvar "osmode"))
    (setvar "osmode" 0)
    (setq ss2 (ssget "x" '((0 . "INSERT")(2 . "Da1drsht"))))
    (setq n (sslength ss2))
    (setq index 0)
    (repeat n
        (setq en (ssname ss2 index))
        (setq el (entget en))
        (setq inspt (assoc 10 el)) ; insertion pt
       (setq xmin (- (cadr inspt) 6.0))
       (setq ymin (- (caddr inspt) 6.0))
       (setq xymin (strcat (rtos xmin 2 1) "," (rtos ymin 2 1)))
       (setq xmax (+ xmin 813.0)) ; hard coded for 813 wide 6mm offset
       (setq ymax (+ ymin 566.0)) ;hard code for 566 high
       (setq xymax (strcat (rtos xmax 2 1) "," (rtos ymax 2 1)))
      (COMMAND "-PLOT"  "Y"     "" "//PRODPRN01/Design-5100"
            "A3" "M"     "LANDSCAPE"   "N"
            "W"   xymin   xymax "1=2"  "C"
            "y"   "Designlaser.ctb"      "Y"   "" "n"   "n"
            "y" "N" "N" "Y"
      (setq index (+ index 1))
    (setvar "osmode" oldsnap)
    Senior Member
    AutoCAD 2009
    Oct 2012
    337
    FrancescoITA
    Add example file.
    Forum Newbie
    Electrical
    AutoCAD 2017
    Jan 2017
    8
    For Bigal:
    Thank you very much Bigal, after i will try if it runs or no.
    However i prefer use a VBA for this script
    For Maratovich:
    Excuse me, here the example.
  5. #5
    Senior Member
    AutoCAD 2009
    Oct 2012
    337
    Look at the options of this topic, there is a solution.
    http://www.cadtutor.net/forum/showth...om-model-space
    http://www.cadtutor.net/forum/showth...ser-paper-size
    You need to batch printing or creating layouts ?
  6. #6
    Forum Newbie
    Electrical
    AutoCAD 2017
    Jan 2017
    8
    For Bigal:
    Excuse me Bigal for my ignorance, but how can i use your script, because i tried, but AutoCad told me that there are some problems.
    Can you tell me what steps i must do to load and to use your script??^^
    Thank you very much .
  7. #7
    Forum Newbie
    Electrical
    AutoCAD 2017
    Jan 2017
    8
    I am interested in both thing, but more to create layout.
  8. #8
    Senior Member
    AutoCAD 2009
    Oct 2012
    337
    Quote Originally Posted by FrancescoITA View Post
    Batch Printing example:
    https://youtu.be/-zVWtNBjPLE
  9. #9
    Forum Newbie
    Electrical
    AutoCAD 2017
    Jan 2017
    8
    maratovich....it is a payment tool....I want create a tool with VBA and i would pay ....
  10. #10
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,601
    Some bits you need to change are shown in red, copy and paste my 1st post to Notepad save as "Plot-Multi-Mspace.lsp". make changes to the code as shown below, post a dwg with say two title blocks a RAR is a nuisance for me then could change code for you.
    To run type Appload and pick the lisp Load & close it should run.
    Code:
    ; By Alan H 2013
    (setvar "osmode" 0)
    (setq ss2 (ssget "x" '((0 . "INSERT")(2 . "Da1drsht")))) ; title block name
    (setq index 0)
    (repeat n
        (setq inspt (assoc 10 el)) ; insertion pt of title block
       (setq xmin (- (cadr inspt) 6.0)) ; offset pt lower left
    ; scale 1=2 is for an A1 sheet plotted on A3 paper
    ; dwg to pdf means we can check if it works rather than waste paper
      (COMMAND "-PLOT"  "Y"     "" "DWG to PDF"
            "y" "N" "N" "Y"
  1. Multiple closed polyline areas
    By Bender in forum AutoCAD Beginners' Area
    Last Post: 14th Apr 2014, 07:37 pm
  2. Adding the sum of Multiple Areas
    By Wise in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 11th Jun 2010, 07:26 am
  3. How to calculate multiple areas?
    By BenGoble in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 1st Jun 2009, 08:03 pm
  4. How to calculate areas of multiple polylines?
    By xyz001 in forum AutoCAD Drawing Management & Output
    Last Post: 13th Feb 2007, 10:24 pm
  5. how do i plot all in black except for shaded areas
    By brentonsavio in forum AutoCAD General
    Last Post: 18th Jan 2006, 07:19 pm
Tags for this Thread
