comcu Posted January 19, 2017 Share Posted January 19, 2017 Hi I want to be able to select an unlimited amount of times just after copy base point, see macro below, any suggestions? ^C^C_copybase;\\\\^C^C_pasteblock;\^C^C_erase;p;; many thanks Quote Link to comment Share on other sites More sharing options...
steven-g Posted January 19, 2017 Share Posted January 19, 2017 Unfortunately thats not an option in LT. You can get a macro to pause for a window selection, to select a single object or for 10 objects, but not for a variable amount, it has to be hard coded into the macro. One possible method would be select your objects first and then run the macro to create the block? ^c^c^ccopybase;\pasteblock;\erase;p;; But other than that there aren't a lot of options unless you want to create individual macros for each case 1,2,3,4,5 etc. Quote Link to comment Share on other sites More sharing options...
Allan_a_AcadLT_User Posted January 19, 2017 Share Posted January 19, 2017 Select prior is a good suggestion and the take out the pause character and replace with letter p, I will try tomorrow. Thanks for helping Quote Link to comment Share on other sites More sharing options...
