Page 1 of 7 1 2 3 ... LastLast
Results 1 to 10 of 62
    Full Member
    Architectural
    AutoCAD 2014
    Jan 2017
    95
    Default How to draw lines/polylines in a specific linetype scale everytime?
    I am aware of changing the linetype scale of entities through the properties box.
    But I cannot figure out how to set in a way that every line I draw will be in that specific linetype scale.
    How do I do that?
    AutoCAD 2013
    Nov 2011
    6,056
    You can use the LTSCALE command to set your current linetype scale. It won't change unless you actively change it by specifying a new LTSCALE.
    Be warned that there is another command which could come into play, which is PSLTSCALE, which defines the PAPER SPACE linetype scale, independently of the Model space, which will defer to the current LTSCALE setting on your machine.
    Every time you draw a new line or polyline, the CURRENT LTSCALE is applied.
    Full Member
    Architectural
    AutoCAD 2014
    Jan 2017
    95
    Quote Originally Posted by Dadgad View Post
    LTSCALE did not work.
    I set LTSCALE as 200. I drew a polyline. The linetype scale for that line is still 1.
    I use LTSCALE command before to change the gobal scale of how linetype will be viewed. But is has never allow me to change the linestype scale of the drawn entity.
    What gives?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    You can change the linetype scale of a single entity via the Properties palette.
    Are you drawing "to scale" as one might do manually on a drafting board?
  5. #5
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    There is probably a better way to do what you are trying to do. Please describe your goal and maybe we can suggest better ways.
    Drafting is a breeze.
  6. #6
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    Quote Originally Posted by tive29 View Post
    What gives?
    LTSCALE may not change the linetype scale of objects with individual property overrides.
    If that is not the case, did you REGEN?
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  7. #7
    Full Member
    Architectural
    AutoCAD 2014
    Jan 2017
    95
    That worked. Thanks Mr ReMark.
    Alternatively, is there a keyboard command or system variable that can be entered by a lisp or macro to a specific line type scale when any drawing is open?
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    I personally think that would be a bad idea unless you only work on one type of drawing exclusively.
  9. #9
    Full Member
    Architectural
    AutoCAD 2014
    Jan 2017
    95
    Although I work on a few different projects, I normally focus on 1 for a couple of days so the line type scale of the entities I draw will be the same for thoes few days. If switching to another projects, I just need to make a change in the lisp/system variable/macro provided if such alternatives exists
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    And how many different linetype scales are we talking? Three? Twelve? One hundred?
  1. Replies: 4
    Last Post: 18th Jan 2011, 12:06 am
  2. how can i change linetype scale for dashed lines to make the visible?
    By michael256 in forum AutoCAD Beginners' Area
    Last Post: 22nd Apr 2010, 12:11 am
  3. My lines skyrocket out of the screen. How to draw in scale?
    By Qumad in forum AutoCAD Beginners' Area
    Last Post: 23rd Nov 2009, 11:45 am
  4. Specific Linetype
    By SmD71nG in forum AutoCAD General
    Last Post: 14th Jul 2009, 03:45 am
  5. Count amount blocks and length specific polylines
    By SstennizZ in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Jul 2008, 03:33 pm
