Page 2 of 7 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 62
  1. #11
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    Quote Originally Posted by RobDraw View Post
    There is probably a better way to do what you are trying to do. Please describe your goal and maybe we can suggest better ways.
    For most people 99% of the time, the line type scale per entity should be 1 letting the variables and annotative scaling handle the way the linetypes appear. If you need to change as often as you are saying, you are doing something wrong.
    Drafting is a breeze.
  2. #12
    Full Member
    Architectural
    AutoCAD 2014
    Jan 2017
    95
    And how many different linetype scales are we talking? Three? Twelve? One hundred?
    around 9 to 10.
  3. #13
    Full Member
    Architectural
    AutoCAD 2014
    Jan 2017
    95
    I personally would use 1 but I have not much of a choice since the office drawing has already been setup this way.
  4. #14
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    You could always record a macro for each linetype scale you typically use naming them by the scale factor so for example you might have macros named LTS1, LTS5, LTS10, etc. LTS = line type scale. It would take less than a minute to record and save all nine and they would be available no matter what drawing you are working on.
  5. #15
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    I'd be willing to bet that it would take much less time to fix the drawing than it will to have to adjust the linetype scale manually all the time.
  6. #16
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,713
    We do have a problem with some custom linetypes and find that at times we tweak them using "properties" for an individual line. LTSCALE is a global variable and changes all lines.
    Only way to sort of automate it would be to use Chprop "Last" s scale but it has to be done straight after drawing the line.A macro or defun lt25 for scale 0.25
  7. #17
    Full Member
    Architectural
    AutoCAD 2014
    Jan 2017
    95
    There is so many different linetypes hundreds or maybe thousands in a single drawing & not having the default names but have funny weird names to it. I really do not think trying to fix the hundreds of drawing is the right approach since all I am doing is, in a sense, is lightly touching the drawing only by adding additional lines (hence prefer to have the correct linetype scale to began with so that I do not have to change those new entities after I drew them)
  8. #18
    Full Member
    Architectural
    AutoCAD 2014
    Jan 2017
    95
    Quote Originally Posted by BIGAL View Post
    What is the keyboard command? LTS only change the global scale & not the scale of the entity that is to be drawn.
  9. #19
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,146
    Quote Originally Posted by tive29 View Post
    There is so many different linetypes hundreds or maybe thousands in a single drawing & not having the default names but have funny weird names to it........
    Therein lies your problem.
    AutoCAD has only about 50 standard linetypes. The rest would be custom written with probably no standard as to how they scale, or possibly imported from another cad programme.
    For LTScale to work consistently, you have to have all linetypes defined consistently.
  10. #20
    Full Member
    Architectural
    AutoCAD 2014
    Jan 2017
    95
    Quote Originally Posted by eldon View Post
    I am not using their linetype or layer to draw in this existing drawing. I am not touching those.
    I am drawing additional lines to this drawing using my own single layer that has a standard autocad linetype which is "DOTTED" to draw the entities.
    To have my newly drawn dotted line using MY OWN layer to look dotted & not "continuous" due to the drawing GLOBAL LINETYPE SCALE setting (which i cannot change since it will affect the rest of the linetype).
    Hence the new entities I am to draw USING MY OWN LAYER cannot be "1".
    ReMark has suggested changing the linetype scale in the Properties palette BEFORE drawing the lines. WHICH WORKS.
    However, alternatively all I am askingis, is there a keyboard command that i can turn it into a macro or a LISP that can activated to change the linetype scale (NOT LTSCALE) before I start drawing without opening the properties palette.
  1. Replies: 4
    Last Post: 18th Jan 2011, 12:06 am
  2. how can i change linetype scale for dashed lines to make the visible?
    By michael256 in forum AutoCAD Beginners' Area
    Last Post: 22nd Apr 2010, 12:11 am
  3. My lines skyrocket out of the screen. How to draw in scale?
    By Qumad in forum AutoCAD Beginners' Area
    Last Post: 23rd Nov 2009, 11:45 am
  4. Specific Linetype
    By SmD71nG in forum AutoCAD General
    Last Post: 14th Jul 2009, 03:45 am
  5. Count amount blocks and length specific polylines
    By SstennizZ in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Jul 2008, 03:33 pm
