Remove annotation scales
sivapathasunderam
Dear colleagues,
Some of my dwgs when I open message appears as
Xref_LAYOUT_2D.dwg contains 189 annotation scales.
It is recommended you open and resave the Xref file to remove excess scales.
What I have to do?
thanks
Siva
Did you try opening and resaving the xref file to remove excess scales?
Did you try using the scale list cleanup utility for AutoCAD 2013/2014?
Thanks for suggestion to my thread
I have downloaded the scale list cleanup utility for AutoCAD 2013 from Autodesk website
Siva
