Results 1 to 3 of 3
    Junior Member
    AutoCAD 2016
    Feb 2016
    20
    Default Architecture Modeling
    Hi all,
    I am new to revit and just having a play around with modelling a clock tower.
    I have made this through component > model in place. The reason I did this is because I don't know any other way of modelling this
    Could you guys let me know how you would create walls or buildings like an old church would have because I don't think it's right that I would do this all in component, right?
    Thanks for any help on this.
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    9,074
    Good work for all in-place components. All of what you've created can be done with actual system and loadable Families in their proper category.
    A great book for architecture would be the Aubin/Stafford release:
    https://www.amazon.com/Aubin-Academy...t+architecture
    There are also samples that come installed. There are tutorials online, YouTube videos can help, and one of the most common advice to getting familiar with Revit on your own is to model your home (eyeball and rough dimensions). You need first to understand the Project Browser, the Ribbon, the Properties Palette, System vs Loadable Families, Levels and Grids, Views, and so forth. These would be just the basics.
    As for specifics as an old church design, Aubin's book on classical architecture in Revit would probably be very helpful:
    https://www.amazon.com/Renaissance-R...l+architecture
    Hope this helps!
    -TZ
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Junior Member
    AutoCAD 2016
    Feb 2016
    20
    Thank you for the reply TZ.
  1. Autocad architecture - Ground surface modeling
    By zionshea in forum Architecture & ADT
    Last Post: 12th May 2016, 10:56 pm
  2. revit architecture & architecture
    By kililio in forum Revit Architecture
    Last Post: 25th Jan 2013, 05:34 pm
  3. Autocad Architecture v Revit Architecture
    By redrickyd in forum AutoCAD General
    Last Post: 12th Oct 2011, 03:40 pm
  4. Architecture 2011 to Architecture 2009
    By NKG in forum Revit General
    Last Post: 29th Dec 2010, 08:59 pm
  5. autocad architecture vs. revit architecture
    By michaeloureiro in forum Software & Licensing
    Last Post: 26th Aug 2009, 07:55 pm
