Results 1 to 5 of 5
    Full Member
    Civil
    AutoCAD 2015
    May 2016
    79
    Default Need help combing two Lee Mac LISPS
    Hey guys!
    So the amazing Lee Mac wrote two different versions of a LISP based on a request I posted. Workflow demands have changed and now I need to modify the lisp to be somewhere in between the two versions.
    Version 1 & Version 2.
    For the combo lisp, I need:
    1. The block multileader to populate from the block's description, rather than name (like it does in Version 1).
      If there is no description, then the contents should default on block name (not from either version, but it would be helpful. I'm not sure how tricky it would be to code)
    2. The block multileader to automatically start at the block's insertion point (like it does in Version 2).
    3. The hatch multileader component is perfect in both versions (pulling the name and prompting for first click as insertion point)
    I tried fiddling around with it, but am too much of a noob to really make heads or tails of what's going on between the two versions (to my amateur eyes, the methods used between the two are too different for me to reconcile).
    Thanks for any help!
    Super Member marko_ribar's Avatar
    marko_ribar's Computer Details
    Windows 7 Ultimate X64
    Intel quad core CPU 4x2.66GHz, 8GB RAM
    INTEL compatibile
    quad core 4x2.66GHz
    8GB
    NVIDIA GeForce 6600 GT
    250 GB
    500 GB
    Samsung 17''
    Architectural
    marko_ribar's Discipline Details
    Architecture, project designer, project visualisation
    Architectural
    space design - modeling and animations
    AutoCAD 2014
    Feb 2010
    Belgrade, Serbia, Europe
    1,290
    If I understood correctly... (So simple - you could certainly figured this out...)
    Code:
    (defun c:hbml ( / blk ent enx sel str )
      (vl-load-com)
      (setq blk (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))))
      (if (setq sel (ssget "_+.:E:S" '((0 . "INSERT,HATCH"))))
          (command "_.mleader")
          (if (= "INSERT" (cdr (assoc 0 (setq enx (entget (setq ent (ssname sel 0)))))))
            (command "_non" (trans (cdr (assoc 10 enx)) (cdr (assoc -1 enx)) 1))
            (command "\\")
          (if (= "INSERT" (cdr (assoc 0 enx)))
            (if (/= "" (setq str (vla-get-comments (vla-item blk (vla-get-name (vlax-ename->vla-object ent))))))
              (command "\\" str)
              (command "\\" (cdr (assoc 2 enx)))
    Marko Ribar, d.i.a. (graduated engineer of architecture)
    M.R. on YouTube
    Full Member
    Civil
    AutoCAD 2015
    May 2016
    79
    Thanks, Marko for writing this. Unfortunately, it looks like it's pulling the block's name, not the description. I'd like it to default on pulling the description and then fall back on using the name only if there is no description.
    Edit: My bad, I was implementing the wrong thing. Yours actually seems to work just fine, thanks!
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,592
    Try the following:
    Code:
    (defun c:hbml ( / blk com ent enx )
        (while
            (not
                (progn (setvar 'errno 0) (setq ent (car (entsel "\nSelect block or hatch <exit>: ")))
                    (cond
                        (   (= 7 (getvar 'errno))
                            (prompt "\nMissed, try again.")
                        (   (null ent))
                        (   (= "INSERT" (cdr (assoc 0 (setq enx (entget ent)))))
                            (setq blk (LM:name->effectivename (cdr (assoc 2 enx)))
                                  str (cdr (assoc 4 (tblsearch "block" blk)))
                                  com (list "_non" (trans (cdr (assoc 10 enx)) ent 1) "\\" (if (and str (/= "" str)) str blk))
                        (   (= "HATCH" (cdr (assoc 0 enx)))
                            (setq com (list "\\" "\\" (cdr (assoc 2 enx))))
                        (   (prompt "\nInvalid object selected."))
        (if com (apply 'vl-cmdf (cons "_.mleader" com)))
    ;; Block Name -> Effective Block Name  -  Lee Mac
    ;; blk - [str] Block name
    (defun LM:name->effectivename ( blk / rep )
        (if
            (and (wcmatch blk "`**")
                (setq rep
                    (cdadr
                        (assoc -3
                            (entget
                                (cdr (assoc 330 (entget (tblobjname "block" blk))))
                               '("AcDbBlockRepBTag")
                (setq rep (handent (cdr (assoc 1005 rep))))
            (cdr (assoc 2 (entget rep)))
            blk
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  5. #5
    Full Member
    Civil
    AutoCAD 2015
    May 2016
    79
    Lee Mac, thanks for responding to the Bat Signal. You rock! And I was wrong, it looks like Marko's works as well. But ain't gonna lie, I stick with Lee Mac code when that's an option.
    Thanks again!
  1. PDF LISPs
    By nicolas in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Sep 2011, 04:13 pm
  2. Help combing two macro's
    By AndyC in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 11th Nov 2010, 07:36 pm
  3. What do these lisps do?
    By chelsea1307 in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th Dec 2008, 07:28 pm
  4. Lisps
    By DJM001 in forum AutoCAD Beginners' Area
    Last Post: 28th Apr 2006, 09:53 pm
Tags for this Thread
