sivapathasunderam Posted February 1, 2017 Share Posted February 1, 2017 Reduce too many segments (vertex) (like line & arc) Quote Link to comment Share on other sites More sharing options...
danellis Posted February 1, 2017 Share Posted February 1, 2017 Look into the OVERKILL command. It looks like that's a survey drawing of some sort, with the sections approximating an arc - in which case OVERKILL won't be much help, sorry. dJE Quote Link to comment Share on other sites More sharing options...
scj Posted February 1, 2017 Share Posted February 1, 2017 Google for WEED.lsp Good luck Jochen PS.: It's hard to convert line segments back to arcs... Quote Link to comment Share on other sites More sharing options...
Dana W Posted February 1, 2017 Share Posted February 1, 2017 I have gone as far as tracing over these types of messes with continuous polyline arcs. (start a polyline then type A. arcs will draw until you left click or type L. Some adjustment is needed afterwards. I've also traced the same way with splines. Then erased the problematic ones. Of, course if one has to stick to coordinates these workarounds may not help much, as they may not be precise enough. Quote Link to comment Share on other sites More sharing options...
