Results 1 to 5 of 5
Thread: Help needed!
    Full Member
    AutoCAD 2013
    Jul 2014
    39
    Default Help needed!
    Hi everyone! i need help of more experienced than myself inventor users..
    How can I add material inbetween the drawing contour and surface of highlighted facets?
    https://www.dropbox.com/s/im5o6mb2fc...oblem.png?dl=0
    https://www.dropbox.com/s/aba5cccr6o...opfig.ipt?dl=0
    I've been trying to do this for two days now to no avail
    Please please help!
    Thank you!!!
    Forum Deity shift1313's Avatar
    not applicable
    Sep 2008
    VA
    3,249
    assuming the edges are coincident to the edge you are trying to add to you have a few options. Delete the faces and then just patch up to that edge. It kind of depends on what you want it to look like. I opened the file and its not immediately apparent what you are trying to do. Are you trying to blend to that curve into an edge, extrude it up or what?
    Because of some geometry problems it won't let you apply tangency with the upper edge but i used the LOFT tool to do this. Your sketch was one section, the upper edge of the solid that i went to was the second section. I simply grabbed 7 or 8 edges on the solid. I then added 2 rails going from your sketch up to the second section. If this is what you are trying to do i can explain it a little better.
    Matt - Certified Solidworks Expert -Advanced Surfacing, Mold Tool and Sheet Metal Specialist
    Current Software: SolidWorks17,Mastercam2017, fusion360, Inventor 2017, HSMworksUltimate
    http://www.solidbox.tv Free and Paid Tutorials for Solidworks, Mastercam and Fusion360
    http://www.mysolidbox.com/ CAD and CAM optimized workstations and laptops
    Full Member
    AutoCAD 2013
    Jul 2014
    39
    shift1313, thank you, that's exactly what I need!
    Initially, I tried applying LOFT, but it didn't work for some reason.. I can't highlight all the facets at once, and an error occurs when I highlight them one by one (see the pic).
    Please please explain how you did that!
    Thanks again!!!
    not applicable
    Sep 2008
    VA
    3,249
    I sent you a PM last night with a video link.
  5. #5
    Full Member
    AutoCAD 2013
    Jul 2014
    39
    shift1313, replied in PM.
    Thanks a million!!!!
  1. Just What I Needed
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 25th Jun 2014, 09:40 pm
  2. Help Needed
    By dsibbo in forum AutoCAD Drawing Management & Output
    Last Post: 7th May 2014, 05:00 pm
  3. Help Needed
    By jlythgoe in forum SolidWorks
    Last Post: 15th Jan 2012, 09:03 pm
  4. help needed C3D
    By matt sad in forum AutoCAD 3D Modelling & Rendering
    Last Post: 29th Aug 2011, 12:29 pm
  5. Help needed
    By ChrisN in forum AutoCAD Drawing Management & Output
    Last Post: 20th Feb 2007, 05:35 pm
