Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    Full Member
    AutoCAD 2015
    Aug 2013
    88
    Default Creating a solid from 3D Faces
    Hello,
    I tried to create a solid using 3dpoly but for some reason I am not able to transform this closed 3dpolylines into surfaces.
    Then I just created 3dfaces.
    How do I generate a solid using all of this 3dfaces?
    Thank you
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    What exactly are you trying to create that first tried using a 3Dpolyline then switched to a 3DFace?
    While I am waiting on a reply, and without the benefit of knowing/seeing what you are attempting to create, I will suggest one possible solution. Convert the 3Dfaces to surfaces using CONVTOSURFACE then use the SURFSCULPT command to generate the required solid. Caveat: the surfaces better be watertight otherwise SURFSCULPT will fail.
    Still no reply?
    OK. Here is a second possible solution that I thought of. Find and use the F2S lisp routine created by Bill Gillis. It is described thusly...
    F2S.lsp creates a single ACIS solid from selected 3dfaces, touching or not
    If neither one works then you did something wrong and I have no other solutions to offer other than to recreate the object from scratch using a different method.
    Full Member
    AutoCAD 2015
    Aug 2013
    88
    It seems I did everything you mention in your post. Convtosurface didn't work with 3dpoly (or randomly worked), also using surfsculpt doesn't work with the surfaces created from 3dfaces.
    I tried F2S and the solid created is not even close to how the solid should look like.
    I thought that Convtosurface will turn all the closed 3dpolylines into surfaces, but as I said It is not consistent (only surfaces parallel with X plane were created). Any idea why this is happening?
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    You want me to diagnose the problem without the benefit of seeing a drawing? No can do. Attach a copy of the drawing to your next post. If the file size is too large then upload it to a file sharing website like DropBox then post a link to it here.
  5. #5
    Full Member
    AutoCAD 2015
    Aug 2013
    88
    This is what I was talking about.
    Thanks
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    See if this works for you. I've got to go shovel out from under 10"+ of snow.
    3DSolid as requested.dwg
    Saved in 2010 file format.
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Don't bother with the drawing above. I like this one better.
    3DSolid from lofted closed polylines and two surfaces.dwg
    The name of the drawing will give you some clue as to what I did. To pull it all together I used the SURFSCULPT command.
    Got to go now. Have fun.
  8. #8
    Full Member
    AutoCAD 2015
    Aug 2013
    88
    What did you do after the Loft?
    How did you create the top and btm surfaces? with Surfpatch?
    For solid did you use Surfsculpt?
    Thanks
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    After the loft I created the top and bottom surfaces using lines and the EDGESURF command. Then it was a matter of just using SURFSCULPT to create the solid.
  10. #10
    Full Member
    AutoCAD 2015
    Aug 2013
    88
    Great, I forgot about Edgesurf command.
    Thanks for the help.
  1. Help with creating a solid out of faces.. or suggest a solution
    By Murphy625 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 11th Oct 2015, 08:22 pm
  2. 3D faces or surface to 3D solid model
    By nic6911 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 17th Sep 2013, 04:45 pm
  3. Extruding faces on a 3D solid question.
    By Cerberus in forum AutoCAD 3D Modelling & Rendering
    Last Post: 8th Nov 2010, 03:25 pm
  4. Rendering faces of a solid in 3D Max
    By xoom2 in forum UVW Mapping, Textures & Materials
    Last Post: 1st May 2004, 11:50 am
  5. Extrude faces on a solid
    By Orbit in forum AutoCAD General
    Last Post: 23rd Jun 2003, 04:56 pm
