Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    Forum Newbie
    Manufacture
    AutoCAD 2013
    Feb 2017
    8
    Default Disappearing annotations in AutoCAD Mechanical 2013
    Hello all,
    I'm new to the forum and I'm having an issue with my annotations disappearing when I try to dimension anything in ACAD Mechanical. I've ran into this issue before, but can't recall the solution. I'll select 2 endpoints, drag the dim line off the part, then rmb to select location. An editable box will show up with the dim, but after i confirm the dim, it goes away. If I open the drawing in a version of ACAD classic, I don't have the issue. If I recall correctly, it was a very simple setting or shortcut that got enabled/disabled.
    Any info would be appreciated!
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    Is the dimension layer off or frozen? Is the dimension annotative, without the current view scale assigned to it.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    Forum Newbie
    Manufacture
    AutoCAD 2013
    Feb 2017
    8
    Quote Originally Posted by Dana W View Post
    Thanks for the response, Dana. The layer is on and not frozen. This happened with another user in my office in the past and the solution was simple (similar to an ANNOALLVISIBLE command). Once enabled, all the dimensions they had been trying to assign showed up at once.
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    Quote Originally Posted by mmcclure View Post
    Apparently your dimensions/Mleaders/text are annotative then. They are disappearing because the current view scale is different than whatever annotation scale is assigned to your annotations.
    I can't remember the exact command name off hand, but there is a button, an annotation icon on the task bar. Turn it on and It will automagically add the current view scale to all the dims in the view area when the view scale changes, either in modelspace or a paperspace viewport. I am not sure the current view scale will be added to existing dimensions from before it is turned on, but if it doesn't , in modelspace just change the view scale to something else, and change back again. Some people don't like the scales added automatically, because it affects all the dimensions in the current space, so when you go to edit one, like MOVE or COPY you see ghost images of the selected annotation at all scales assigned to it at once. That can be kinda cloogie to look at.
    The button should be right next to the other identical annotation icon (ANNOALLVISIBLE) down there on the task bar (or up on the annotation ribbon tab) where you change the view scale. it's something like ANNOAUTOSCALE. If you have tool tips turned on just hover till you find it. Without the automatic function turned on, you can select the dimensions and manually add the desired scale to them using the right clock menu, or the Properties pop up dialog window.
  5. #5
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,127
    Are these regular AutoCAD dimensions or Mechanical Power Dimensions or both?
  6. #6
    Forum Newbie
    Manufacture
    AutoCAD 2013
    Feb 2017
    8
    Quote Originally Posted by SLW210 View Post
    Power dimensions.
  7. #7
    Forum Newbie
    Manufacture
    AutoCAD 2013
    Feb 2017
    8
    Thanks. I'll look into this today.
  8. #8
    Forum Newbie
    Manufacture
    AutoCAD 2013
    Feb 2017
    8
    Dana,
    The other dims/text in the dwg are not annotative, so i'm not sure if that's what i'm looking for. Annotation visibility and annotation scale didn't do the trick either. I've had them switch to classic from mechanical and just use DIMLINEAR instead of the Power dimensions in Mechanical. They are fine with this, but I'm going to be frustrated until I can figure out the issue! Thanks for your help.
  9. #9
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    Dana,
    Then there may be some phenomenon in mechanical dimensioning working against you. I am not familiar with the vertical products, so I hope someone else steps in. Just make sure that the dims that are disappearing either or or are not annotative so you can either keep or exclude annotative as a clue.
  10. #10
    Forum Newbie
    Manufacture
    AutoCAD 2013
    Feb 2017
    8
    Thanks Dana.
  1. are mechanical 2013 & full desktop 2013 drawing files compatible?
    By michaelmcneil in forum Mechanical & MDT
    Last Post: 4th Dec 2014, 02:49 pm
  2. AutoCad Mechanical 2013 Content Library
    By delliott in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 4th Oct 2013, 01:22 pm
  3. Autocad Mechanical 2013 Power Dim Text
    By harley558 in forum Mechanical & MDT
    Last Post: 19th Oct 2012, 10:00 pm
  4. AutoCAD Mechanical 2013 Commandline Docking
    By CADGUY7779 in forum AutoCAD Beginners' Area
    Last Post: 17th Sep 2012, 07:50 pm
  5. Migrating content center from AutoCAD Mechanical 2012 to 2013
    By NoelStalker in forum CAD Management
    Last Post: 9th May 2012, 06:49 pm
