Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    We can eliminate all doubt, if you could post a file exhibiting the behavior.
    Drafting is a breeze.
  2. #12
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,947
    I moved your thread to the Mechanical & MDT Forum, perhaps it is a Mechanical specific problem.
    Yes, posting a .dwg would certainly help eliminate some things.
  3. #13
    Forum Newbie
    Manufacture
    AutoCAD 2013
    Feb 2017
    8
    Quote Originally Posted by SLW210 View Post
    Thanks for everyone's input. As i was paring down the file to upload, i found a mechanical layer that was frozen, but it was not the layer that i was trying to use to apply the dimension with. I feel like an idiot. I guess now my question is how is that association made, but i should probably ask that on a different forum. I don't use Mechanical very often, so maybe that's my issue?
  4. #14
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,743
    This has probably already been covered, but I am too tired right now to re-read the thread, and I can't remember.
    Are you working through a viewport? If so, is your dim layer frozen in that one viewport? The way I learned about this technique many years ago, was by being confronted with someone else's drawing with two dimension layers, DIMS and DETAIL DIMS. DIMS was frozen in all the detail (large scale) viewports, and DETAIL DIMS was frozen in all the rest.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  5. #15
    Forum Newbie
    Manufacture
    AutoCAD 2013
    Feb 2017
    8
    I can look into it tomorrow. I didnt create the original, so I don't know how the drawing was originally set up.
  1. are mechanical 2013 & full desktop 2013 drawing files compatible?
    By michaelmcneil in forum Mechanical & MDT
    Last Post: 4th Dec 2014, 02:49 pm
  2. AutoCad Mechanical 2013 Content Library
    By delliott in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 4th Oct 2013, 01:22 pm
  3. Autocad Mechanical 2013 Power Dim Text
    By harley558 in forum Mechanical & MDT
    Last Post: 19th Oct 2012, 10:00 pm
  4. AutoCAD Mechanical 2013 Commandline Docking
    By CADGUY7779 in forum AutoCAD Beginners' Area
    Last Post: 17th Sep 2012, 07:50 pm
  5. Migrating content center from AutoCAD Mechanical 2012 to 2013
    By NoelStalker in forum CAD Management
    Last Post: 9th May 2012, 06:49 pm
