samifox Posted February 12, 2017 Share Posted February 12, 2017 hi ive made a field that describe the axes of a block (Level symbol) im using centimeter but i want to use the field to display meters for example moving a level 125 units, i want it to display 1.25 is that possible? Tx S Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 13, 2017 Share Posted February 13, 2017 To quote a Google search "add a formula to your field" 2nd answer Search "Formula in autocad field" Quote Link to comment Share on other sites More sharing options...
samifox Posted February 13, 2017 Author Share Posted February 13, 2017 hi for those want to achieve conversion to other scale units in a field for example, for level symbol 1.set the field to read to Y of a block 2.copy the expr 3.select a formula category 4.paste the expr 5.evaluate 6.set the desired format and conversion factor Thanks S Quote Link to comment Share on other sites More sharing options...
