Results 1 to 8 of 8
    Senior Member
    AutoCAD 2015
    Jan 2015
    148
    Default "matchprop" command with haches problem
    Hello everyone, I'm trying to "matchprop" some hatches but something gets wrong..
    The final result isn't as it should be...
    I've recorded a gif to explain this strange behavior.
    https://media.giphy.com/media/l3q2XX...6pG/source.gif
    This is not the first time that happens, how could I fix that?
    Thanks, Dennis
    example.dwg
    AutoCAD 2013
    Nov 2011
    6,056
    Open the Hatch Dialog, by starting the HATCH command, if you wish to use an existing hatch as a reference, select it as shown in the screenshot, then choose one of the Boundaries option, and start clicking away.
    Don't select the hatch before starting the MATCHPROP function. Click on the icon, then define your hatch selection by clicking within a hatched area.
    Be sure that when you click into the hatch you wish to replicate, that a portion of the linework which makes up the hatch is visible within your PICKBOX, meaning don't click in a void in the hatch pattern.
    As shown in your gif, you are attempting to match the hatch properties of a valid hatch into an UNHATCHED area, which by definition has no HATCH PROPERTIES to alter, there's the rub. If another area already is hatched you can do it that way. If it is empty, you cannot.
    Senior Member
    AutoCAD 2015
    Jan 2015
    148
    Hi! thank for your reply!
    I wasn't try to matchprop an area without hatch.. it was only the result of a previous attempt to matchprop.. the scale gets alterate after the matchprop.
    as you can see they all have the same proprieties but they look different.
    I have to change the scale from 0.8 to 0.03 in order to make them look the same.
    AutoCAD 2013
    Nov 2011
    6,056
    Now I understand what you are describing. I hadn't realized that what you were clicking on was a line in the hatch pattern.
    How did you apply the hatch in the first place, that they represent differently? That would seem to be the key to, the behavior being demonstrated, which I have never seen before.
  5. #5
    Senior Member
    AutoCAD 2015
    Jan 2015
    148
    Unfortunately it's not my dwg, I get this drawing from a customer. In the two diagonal walls there was another hatch, I just wanted to uniform them.. but it doesn't work
    I've uploaded the dwg if you want to look to.. I fixed it by changing it to Ansi37 but that's very strange ... :S
  6. #6
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,163
    From what I could find it's caused by having the same name of hatch, but one being imperial and the other metric somehow getting into in the same drawing, which if you look at the two hatches in your drawing shows a distance between the hatch lines in one as 0.1 and the other as 2.54 So that sounds plausible. You can get them to match up again by selecting all hatches of that type and in the properties giving them the same scale, but that may need a bit of trial and error to find the correct scale for your drawing, 0.031496 looks perfect. And if you regognise the numbers that is 0.03937*0.8.
  7. #7
    AutoCAD 2013
    Nov 2011
    6,056
    Quote Originally Posted by steven-g View Post
    Good work steven-g, I was thinking/wondering about that while I was out for dinner, you nailed it!
    If you select those two hatches which are different, and change the scale in their properties from0.8 to 0.03149, it all looks good to me!
    If one runs the -dwgunits command on the drawing, the units are mms, and those hatches were obviously created with drawing units set to inches.
  8. #8
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,163
    It is actually a problem I recognise seeing myself a few times, I just never really spent much time on it, this reminded me, so did a bit of digging about in that drawing and on the web, and it makes sense. Now next time I come across I'll know the answer
  1. By putting underscore "_", or dash "-" before the name of the command?
    By tipu_sultane in forum AutoCAD Beginners' Area
    Last Post: 7th Jun 2015, 01:06 am
  2. (command "Hatch") Ribbon problem Acad 2011
    By NirantarVidyarthee in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Apr 2012, 03:24 pm
  3. (command "dim" "DIMLDRBLK" "" |) is not working
    By bijoyvm in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Oct 2010, 12:15 pm
  4. funny problem about command "section" in a script
    By phymilton in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Jan 2006, 03:36 am
