Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
    Full Member
    AutoCAD 2015
    Feb 2016
    33
    Default How do I accomplish this rotation?
    Hey guys, another quick one here.
    I'm trying to rotate objects around an ellipse. Here's a quick look at what I'm trying to do:
    I want to rotate that second box on the right so that it faces the center of the ellipse, yet remains connected to the first box at the front corner.
    Here's a close up:
    Basically I want to rotate around the point indicated by the blue circle, and end up where the red line is lined up with the ellipse's center.
    For the life of me, I can't get this to work. I start the ROTATE command, and select that point. Then I hit R for reference, then select two points on the red line, then select the center of the ellipse, but for some reason it only rotates enough as if the blue point were the reference point.
    In other words, this is what I get:
    Am I just totally borking the ROTATE command? Or is this even possible to do?
    Thanks for the help.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2017
    Nov 2005
    Norwalk, CT USofA
    45,954
    Stop giving yourself a headache and download Lee Mac's custom lisp routine called Align Objects to Curve. The demo he provides will give you some idea of how it works. First, however, read the program description.
    http://lee-mac.com/objectalign.html
    Full Member
    AutoCAD 2015
    Feb 2016
    33
    EDIT: Augh, this isn't really what I wanted either. Nevermind. Mods please delete, I can't find the button for that...
    Full Member
    AutoCAD 2015
    Feb 2016
    33
    Holy smokes, very cool! I'll definitely check this out... I have a bunch of different shapes to align to this damn ellipse. This thread was good for something! Thanks!
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2017
    Nov 2005
    Norwalk, CT USofA
    45,954
    Not what you wanted? Please explain what I missed and/or how Lee's Align Objects to Curve fails.
  6. #6
    Full Member
    AutoCAD 2015
    Feb 2016
    33
    Sorry, I mean aligning that red centerline with the center of the ellipse isn't what I wanted; the rotation is too extreme, which makes sense for an ellipse.
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2017
    Nov 2005
    Norwalk, CT USofA
    45,954
    So if you were to rotate the box with the red line in it, and get it (the red line) passing through the center of the ellipse, a portion of the bottom of the box will be inside the ellipse. And that's an acceptable result?
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2017
    Nov 2005
    Norwalk, CT USofA
    45,954
    This is my attempt.
    First image is the "before" rotate. Second image is "after" rotate. Is the second image the result you are looking for?
  9. #9
    Full Member
    AutoCAD 2015
    Feb 2016
    33
    Yep, that's perfect, although after I made the thread I realized that's not exactly what I wanted to begin with. What I really want is to align the "front" face of the green box with the ellipse, which is just a matter of drawing a circle and rotating the box so that the other "front" corner intersects the ellipse. So you end up with an circular segment's worth of the green box that's inside the ellipse, but that's OK.
    But, this is more easily done with that LISP you posted earlier.
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2017
    Nov 2005
    Norwalk, CT USofA
    45,954
    So you now have a workable solution to your problem?
  1. Delete Dynamic Block Rotation Parameter: Keep Custom Rotation in Standard Block?
    By lauraecwalker in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Nov 2016, 11:07 am
  2. I don't completely understand what I need to accomplish with this.
    By StudentOfComputers in forum Student Project Questions
    Last Post: 22nd Oct 2014, 11:31 pm
  3. North Arrow rotation in title block with rotation property editable in SSM
    By rajeev_acpl in forum AutoCAD Drawing Management & Output
    Last Post: 28th Jul 2012, 07:01 am
  4. Rotation of drawings in vieport without model rotation
    By intern2011 in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Sep 2011, 04:02 pm
  5. What will I need to accomplish this?
    By ChadPoehland in forum AutoCAD Drawing Management & Output
    Last Post: 20th Dec 2006, 08:52 pm
