How to make list of point entity
subodh_gis
This is the part of code. I am getting the ; error: bad list of points
How we will make list of points pt1 and pt2 to pass in ssget "_F". please help
(setq txt (entsel "Select text: "))
   (setq oText (vlax-ename->vla-object (car txt)))
   (setq pt1 (vlax-safearray->list (vlax-variant-value (vlax-get-property oText 'InsertionPoint))))
 (setq x1 (car pt) y1 (cadr pt))
(setq angle_obj (vlax-get-property oText 'Rotation))
(setq pt2 (polar pt (+ angle_obj PI 90) 0.3))
       (setq x2 (car pt) y2 (cadr pt))
(setq ss (ssget "_F" '((x1 y1) (x2 y2)) ))
Instead of this:
'((x1 y1) (x2 y2))
Use this:
(list (list x1 y1) (list x2 y2))
Or this:
(list pt1 pt2)
Note: The pt variable seems undefined.
Thanks for response but when I using
error: bad argument type: lselsetp nil
but when we write x y coordinates then the code runs fine. like
(ssget "_F" '((0 0) (1 1)))
so finaly how to make pt1 and pt2 x y coordinate list.
This should explain it somewhat:
(defun c:try ( / txt oText pt1 x1 angle_obj pt2 x2 )
         x1 (car pt1) y1 (cadr pt1)
         heigth_obj (vlax-get-property oText 'Height)
         pt2 (polar pt1 (+ angle_obj 45) heigth_obj)
         x2 (car pt2) y2 (cadr pt2)
         ss (ssget "_F" (list (list x1 y1 0.0) (list x2 y2)))
   (command "line" (list x1 y1) (list x2 y2) "") ; Draw fence line so you can see location.
   (sssetfirst nil ss) ; Set ss as selected and gripped.
No, just that it doesn't matter. Example code nothing more. Started to simplify using the TEXTBOX function, but really
(setq ss (ssadd))(sssetfirst nil (ssadd (car(entsel "Select text: "))))
would do the same thing.
