Results 1 to 8 of 8
    Forum Newbie
    AutoCAD 2011
    Nov 2016
    4
    Default Problem with function ACET-.......
    Hello everybody.
    Can anyone halp me with this code:
    Code:
    defun getfencesel (en flt / fe ss)
          (vl-cmdf "_ZOOM" "_E")
    	  (setq ss (ssadd en))
          (setq fe (acet-list-remove-adjacent-dups (acet-geom-object-point-list en 0.05))
                ss (ssget "_F" fe flt)
          (vl-cmdf "_ZOOM" "_P")
          ss
    Maybe someone known how it rewrite into normal Autolisp or Vlisp??
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    800
    Heres my attempt:
    Code:
    ; (sssetfirst nil (GetFenceSel (car (entsel)) '((0 . "*TEXT")) 3))
    ; (sssetfirst nil (GetFenceSel (car (entsel)) nil 3))
    (defun GetFenceSel ( e flt prec / DivideCurveAtInc Trap pL ll ur SS )
      (defun DivideCurveAtInc ( i c / TotLen d PtLst )
        (if
          (and
            (numberp i) (not (or (zerop i) (minusp i)))
            (not (vl-catch-all-error-p (vl-catch-all-apply 'vlax-curve-getEndParam (list c))))
            (<= i (setq TotLen (vlax-curve-getDistAtParam c (vlax-curve-getEndParam c))))
            (setq d 0.0)
            (while (<= d TotLen)
              (setq PtLst (cons (vlax-curve-getPointAtDist c d) PtLst))
              (setq d (+ d i))
            ); while
            (setq PtLst (reverse PtLst))
          ); progn
        ); if
        PtLst
      ); defun DivideCurveAtInc
      (defun Trap ( f L / r err ) (if (setq err (not (vl-catch-all-error-p (setq r (vl-catch-all-apply f L))))) (if r r err)) )
      (cond
        ( (not (setq e (Trap 'vlax-ename->vla-object (list e))))
          (princ "\nNo object provided.")
        ( (not (Trap 'vla-GetBoundingBox (list e 'll 'ur)))
          (princ "\nInvalid object.")
          (or
            (and
              (Trap 'vlax-curve-getEndParam (list e))
              (setq pL (mapcar '(lambda (x) (reverse (cdr (reverse x)))) (DivideCurveAtInc prec e)))
            (setq pL
                (lambda ( x / p1 p2 ) (setq p1 (car x)) (setq p2 (cadr x)) (list p1 (list (car p1) (cadr p2)) p2 (list (car p2) (cadr p1))) )
                (mapcar '(lambda (x) (reverse (cdr (reverse (safearray-value x))))) (list ll ur))
          ); or
          (vla-ZoomWindow (vlax-get-acad-object) ll ur)
          (and
            (setq SS (ssget "_F" pL flt))
            (ssadd (vlax-vla-object->ename e) SS)
          (vla-ZoomPrevious (vlax-get-acad-object))
      ); cond
      SS
    ); defun GetFenceSel
    (vl-load-com) (princ)
    Where 'prec is the unit increment for the curve to be divided.
    HTH
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,021
    You could use this in place of acet-geom-object-point-list.
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Forum Newbie
    AutoCAD 2011
    Nov 2016
    4
    I've put wrong code. This is corect:
    Code:
    (defun getfencesel (en flt / fe ss)
          (acet-ss-zoom-extents (setq ss (ssadd en)))
          ss
    The all lisp is here:
    https://www.theswamp.org/index.php?topic=9042.465
    File: TriangV0.6.7.LSP by ymg
    Becouse my CAD don't have Acad Express Tools so I have to change the TriangV0.6.7.LSP.
    I've changed the parts with function:
    pragma
    vl-times
    acet-ui-progress
    ..adne command TIN is working, but PROF still isn't.
    I've put grrr code instead fragment with error but it doesn't work. My knowledge of this is over.
    I'm still using COMAND
    I will be grateful for your help.
    Pawcyk
  5. #5
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    11,377
    Please read the Code Posting Guidelines and edit your Code to be included in Code Tags.[CODE]Your Code Here[/CODE] =
    Code:
    Your Code Here
  6. #6
    Forum Newbie
    AutoCAD 2011
    Nov 2016
    4
    Can I change my posts now? If not I will try do it corectly in the future. My english isn't as good as I want thats why I could missed it.
    Pawcyk
  7. #7
    Forum Newbie
    AutoCAD 2011
    Nov 2016
    4
    Lee Mac your code is working, thank you very much.
  8. #8
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,021
    Quote Originally Posted by pawcyk View Post
    Excellent - you're welcome!
  1. (acet-geom-ss-extents-accurate) function errors in A2016,A2017
    By marko_ribar in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 5th May 2016, 01:58 pm
  2. Problem in IF function
    By mostafa badran in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Apr 2014, 12:45 pm
  3. after loding lisp : "error no function definition , ACET-STR-FORMAT"
    By Salama in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Mar 2014, 11:03 pm
  4. ACET-SS-Filter function
    By ectech in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Jun 2010, 09:33 am
  5. how to use acet-ss-filter
    Last Post: 4th Jan 2010, 09:36 am
