Results 1 to 8 of 8
    Forum Newbie
    Multi-disciplinary
    not applicable
    Feb 2017
    5
    Default Solidworks : How to Draft a L shape groove
    Hello, I'm facing an issue with the Draft feature in solidworks. Probably because I don't practice so much on this soft.
    I do have a L that need to get a 5° angle draft to let the die get in and out.
    Draft doesn't work as the direction have to be both horizontal and vertical at the same time to get a draft on all the walls.
    Is there another tools to achieve this in solidworks
    Thanks for your help.
    Forum Deity shift1313's Avatar
    not applicable
    Sep 2008
    VA
    3,249
    So you are saying the edges along the vertical walls need to be drafted in 5degrees as pulled from vertical, but also normal to them?
    If that is true you can do this in 2 separate draft operations. You can use either the "Neutral Plane" option or the "Parting line" option.
    If you needed it drafted in two different directions it would look like this.
    If you need it to just be pulled from one direction it looks like this.
    If you use the Draft Feature with the Neutral plane option, the selection process looks like this. The pink face is the pull direction. The blue faces are the faces to draft.
    The Second draft selection looks like this. Again the Pull Direction is the pink face and the blue faces are ones to draft.
    If you want to use the Parting Line option, the direction of pull selection is the same, but you select the "parting line" edges for faces you want to draft. There will be a yellow arrow that shows up from that edge pointing in the pull direction
    There are many ways to do this manually as well if you need something a bit more complicated. Surfacing tools to trim or replace faces is one method.
    Matt - Certified Solidworks Expert -Advanced Surfacing, Mold Tool and Sheet Metal Specialist
    Current Software: SolidWorks17,Mastercam2017, fusion360, Inventor 2017, HSMworksUltimate
    http://www.solidbox.tv Free and Paid Tutorials for Solidworks, Mastercam and Fusion360
    http://www.mysolidbox.com/ CAD and CAM optimized workstations and laptops
    Forum Newbie
    Multi-disciplinary
    not applicable
    Feb 2017
    5
    thanks for the clear explanation. I was probably doing something wrong, I will try again.
    Forum Newbie
    Multi-disciplinary
    not applicable
    Feb 2017
    5
    Thanks, so I do have a look again. The problem is that I don't want to draft in the lenght but I want to draft on the width as per the drawing thereafter. I can get the same result than you lenght wise but not on the other side.
  5. #5
    Forum Newbie
    Multi-disciplinary
    not applicable
    Feb 2017
    5
    Hello, the first issues is still unsolve, but here is a second issu with the draft function.
    Is there another way to create a draft as it is really annoying and time consuming to used the Draft feature on very basic shape?
    Thanks for your advice
  6. #6
    not applicable
    Sep 2008
    VA
    3,249
    I am having a little trouble understanding which direction you are drafting to. If you select the faces you want to draft and then thw direction it should work.
    You can draft during the creation of features like Extrude. You can also manually make drafted facea and use "replace face"
  7. #7
    Forum Newbie
    Multi-disciplinary
    not applicable
    Feb 2017
    5
    Thanks, I was thinking that such basic draft will work, but sounds like I need to used other technic. I will look for the Replace face for the first time. Thanks for your help.
  8. #8
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    Attach your *.sldprt file here and end all doubt.
    (if the original file is proprietary - you should be able to create a simple part that illustrates the geometry shown in your picture)
  1. Constrain pin-in-groove
    By TorqueCAD in forum Autodesk Inventor
    Last Post: 8th Dec 2016, 03:38 am
  2. Replies: 2
    Last Post: 2nd Jul 2016, 05:04 pm
  3. O-ring groove
    By paulmcz in forum AutoCAD 3D Modelling & Rendering
    Last Post: 5th Mar 2015, 06:24 pm
  4. drawing a groove in 3D
    By ryan47371 in forum AutoCAD General
    Last Post: 19th Dec 2007, 08:06 pm
Tags for this Thread
