Results 1 to 5 of 5
    Junior Member
    AutoCAD 2015
    Nov 2014
    11
    Default cleaning IFC links in Revit
    Hello,
    I am an MEP drafter, and this is the first time I am working with a Linked IFC file in Revit (16), The Architect has modelled their building in Rhino, and have exported it in IFC, after changing from SAT exports (due to problems with importing to revit)
    My Question is, after I have linked the IFC model, is there a way to clean all those unnecessary models lines, highlighted in Yellow (in picture below), so we can see the Floors and Walls/windows more clearly??
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    671
    The link converted ifc to _ifc.rvt in the same folder. Open this .rvt a delete these elements..
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    9,074
    If those lines are associated with the Floor category, hiding the Floor would be a "good enough" fix probably.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Junior Member
    AutoCAD 2015
    Nov 2014
    11
    Quote Originally Posted by halam View Post
    Yeah, I tried this, But they show up as slabs and walls, and i Can't physically delete them without deleting the wall.
    I have found out that they are edges, and that I can only hide them by using shaded edges, and unticking "show edges" in model display,
    Unfortunately this is not what I'm after, I still want to show wall outlines without those pesky lines
  5. #5
    Junior Member
    AutoCAD 2015
    Nov 2014
    11
    Quote Originally Posted by tzframpton View Post
    I am hoping for something more, but it is a good work around for now, cheers
  1. Revit Links
    By resullins in forum Revit General
    Last Post: 10th Apr 2015, 05:15 pm
  2. Revit links in view templates
    By kzoppo in forum Revit General
    Last Post: 8th Apr 2015, 07:59 pm
  3. Revit Links
    By addesigns in forum Revit Architecture
    Last Post: 29th May 2013, 05:36 pm
  4. Revit 2014 - Trial Download Links
    By Lee Roy in forum Revit General
    Last Post: 18th Apr 2013, 05:07 pm
  5. Cleaning Up a DWG
    By chris81 in forum AutoCAD Beginners' Area
    Last Post: 26th Mar 2012, 10:55 pm
