Results 1 to 4 of 4
    Junior Member
    AutoCAD 2015
    Dec 2008
    15
    Default Wish To Snap While Running Polyline Command
    While running in Line command I'm able to snap along the way, snap my running line to itself at each sub prompt: "Specify next point or..." When I try this with the Polyline command, while running polyline at each sub prompt: "Specify next point or..." no snap can be acknowledged. My Polyline won't snap to itself while running toward successive points. All Object Snaps are checked in it's dialog box. Alignment Point Acquisition is set to Automatic. Is there another setting or a system variable that needs to be toggled, maybe something related specifically to Polylines?
    Senior Member SunnyTurtle's Avatar
    SunnyTurtle's Computer Details
    Win 10 64bit
    Civil
    SunnyTurtle's Discipline Details
    Drafter CAD
    Civil
    Rail, Roads, Civil
    AutoCAD 2018
    Apr 2011
    Sydney Australia
    161
    You are using an old style of pline
    Set PLINETYPE to 1 or 2 to start using the modern type
    https://knowledge.autodesk.com/suppo...D4874-htm.html
    Junior Member
    AutoCAD 2015
    Dec 2008
    15
    That was it! Thank you. Thank you. Thank you...
    Win 10 64bit
    Civil
    Drafter CAD
    Civil
    Rail, Roads, Civil
    AutoCAD 2018
    Apr 2011
    Sydney Australia
    161
    Not a problem happy to help
  1. Snap Polyline to the block insertion without changing the orientation of Polyline
    By Dhuliya_jay in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Oct 2011, 09:49 am
  2. The procedure of Polyline running points
    By Michaels in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Aug 2010, 03:49 pm
  3. Snap to 2D polyline
    By Rooster in forum AutoCAD General
    Last Post: 13th Aug 2009, 04:06 pm
  4. Polyline snap
    By Barclay in forum AutoCAD Beginners' Area
    Last Post: 21st Dec 2007, 08:02 am
  5. Autocad LT 2004 running object snap - HELP!!!
    By robsa in forum AutoCAD Beginners' Area
    Last Post: 6th May 2005, 05:40 pm
Tags for this Thread
