triangle assembly
chrisdarmanin
i have 3 50x50x3mm profiles with a hole at each end that i want to connect in a triangle. the first 2 holes i constrain with an inset but i cant connect the 3rd hole as there is a gap of 3 mm. i do not want to add a washer because in real life the bend slightly but its negligible.
imagine something like this the triangular structure but all profiles of 50x50x3mm
