Tiger Posted October 14, 2008 Posted October 14, 2008 Hi guys, I've got a bunch of annotative dims that I need to move a bit, I have them set to both 1:20 and 1:50 and it's the 1:50 that I see in Model Space. The problem I have is that when I grab a dimension and pull it a bit, I only move the 1:50-version of it. The 1:20 stays where it is. I'm guessing it's a variable (most things are after all) - anyone know how to fix it?? Quote
NBC Posted October 14, 2008 Posted October 14, 2008 Do you mean move, as in by picking a grip point and dragging ? If so, I have yet to find a variable that will grab all entities contained within an annotative object. If you are using the real move command, they all should move together, however. Quote
Tiger Posted October 14, 2008 Author Posted October 14, 2008 A yes, the gripping-and-dragging-move version. Damn... I was hoping on you Bluey Quote
NBC Posted October 14, 2008 Posted October 14, 2008 The only thing I have found is to set SELECTIONANNODISPLAY to 1; and move one of the annotations; change your CANNOSCALE to whichever scaled version you wish to move next, then drag the relevant grip to your desired location. PITA I know, but at the moment, I don't have the knowledge for a more robust method. Quote
Tiger Posted October 14, 2008 Author Posted October 14, 2008 yeah.. I remove all other annotations and move it and then add annotative scales when needed... Quote
