Hi all!
Does anyone know how to place text on a solid. I feel really dumb asking this question. I can fake it but it's taking so long.
Thanks
On a plan surface of a solid? Extrude the text as showed above. If it's not placed right on the desired surface, Union together the letters for easy manipulation. Place it on the surface -maybe using the ALIGN command. Move, rotate and resize it if needed. Finally use the UNION command again to make the text and the solid as one.
A 4 years old thread recomes to life :)
I've moved this question to it's own thread, so now you can check the "Similar Threads" at the bottom of this page.
Also, have a look at THIS thread. It includes a lisp routine that may be useful. :unsure:
  • 10 months later...
Hello!
Does anyone know how to place text on a solid surfice like a cilinder?
Thanks.
Not a cylinder but a sphere should give you some ideas (see attached). F1 imprint and express tools help txtexp
8-Ball.zip
