Middle button pan and right button object drag doesnt work
Hi,
Recently Ive lost the ability to drag objects by holding the right button. Also, when I select the object and right click, the move command on the shortcut menu does not appear.
I did try to fool around with the CUI to try and restore the scroll button panning (this error occured a while ago but I decided I could live without it). And now for some mysterious reason the right button drag doesnt work.
Also, when I press del, the objects dont delete anymore.
This is all a mystery to me. I have tried to restore the CUI defaults, but to no avail.
please help
Henry - Civil Engineer
ps. also ive tried fooling around with the mouse settings by setting everything to default. Again, no avail.
Plus this doesnt explain why I cant delete using the del key anymore!
Ah I've found the solution on this forum.
pickfirst 1
