Hi Guys,
Wasn't that busy, so I thought I'd put together a little Incremental Numbering Suite for you all to sample.
I've come to realise that this kind of LISP seems to be quite a popular one in many trades, and this was my main inspiration for its creation.
As with all my programs - your comments and/or criticism is welcome, as this only helps to improve the program itself.
Thanks & Enjoy!
Cheers
Lee
Main Dialog Preview:
Content Builder Preview:
About Dialog Preview:
A full description of the program and the latest version can be found here.
Edited by Lee Mac
Now that's sweet, Lee.
I made that change you made for me in a previous version to allow a leading zero in the number, and the rotation ability you put in the program really adds to the utility of it.
But then a small thought came into my head:
What if we need the prefix and the number to be static, and the suffix to increment? Only the prefix and suffix accept alpha input, but neither of these will increment.
Steve
Thanks for your suggestions Steve :)
I suppose I could include options for an incrementing Prefix and/or Suffix, but this would add extra prompts for the user. I shall have a think about this one :thumbsup:
Yep. Too many user prompts would make it a real endurance test, and might possibly turn many potential users away from it.
It's very good as is. I was just tossing out some thoughts.
Steve
Steve
As I said, I like the comments and criticism, (after all, it can only potentially make it better... :P ) and, if I think this is feasible without too much clutter, I may well incorporate it :)
Thanks Steve
Purhaps a "kword" system, i find that is quite helpfull, when trying to steam line a program, or even a kword toggle.
Hey, great routine. This will certainly speed up the creation of “Part Callout” drawings.
The only thing I would suggest is coordinate translation to eliminate the need to have the WCS current.
Ahh good point Sean, thanks :)
I shall endeavour to incorporate that. I only tested it in WCS, so didn't notice the need, but thanks for pointing that out mate :)
Thanks Flowerrobot for your suggestion - I just like to keep the user prompts to a minimum, otherwise the user just sloggs through a load of prompts before he/she can get to the "business" end of the program...
What if I need to get one sets of number without prefix or suffix?
Another thing: What about dcl? Is it pending?
Well, at the minute, I suppose you could use a space for a prefix and suffix - but yes, I shall incorporate the option of none.
Hmmm... I'm not sure about DCL, I may just keep it command line - with DCL, you have the complications of an extra file, and the coding turns "ugly"...
But thanks for the suggestions :)
Here is one way to deal with options:
(defun c:test()
 (setq snum 1
       inc  1
       pre  ""
       suf  ""
 ;;  enter key sends the user on his way
 (while
   (cond
     ((progn
        (princ (strcat "\n*** Start #" (rtos snum 2 0)
                       "  Increment: " (rtos inc 2 0)
                       "  Prefix: " pre
                       "  Suffix: " suf))
        (initget "Start Inc Prefix sUffix")
        (null (setq opt (getkword "\nEnter option to change [start/Inc/Prefix/sUffix]: "))))
        nil
     ((= opt "Start")
      (setq snum (getreal (strcat "\nSpecify Starting Number <" (rtos snum 2 0) ">: ")))
     ((= opt "Inc")
      (setq inc (getreal (strcat "\nSpecify Increment <" (rtos inc 2 0) ">: ")))
     ((= opt "Prefix")
      (setq pre (getstring t (strcat "\nSpecify Prefix <"
                                      (if (eq "" pre) "-None-" pre) ">: ")))
     ((= opt "sUffix")
      (setq suf (getstring t (strcat "\nSpecify Suffix <"
                                      (if (eq "" suf) "-None-" suf) ">: ")))
Thanks for the info CAB, I'll be sure to test that tomorrow when I get a minute :)
Cheers
Lee
This is a preliminary - I am thinking DCL may be a good call - but not sure...
Let me know of your thoughts on this:
Lee,
You should know by now.
DCL is always a good call.
The whole program in your face without anticipation of prompts.
Now thats more like it.
Outstanding work Lee.
Very nice, Lee.
You know what would make a program like this truly powerful? In addition the current option which creates new text, an option to edit existing text (or attributes).
Also for some reason the text angle changes in the middle of executing the program... :confused:
Lee,
One thing I noticed was you cannot have preceeding zero's in the suffix.
(Example: To have a suffix start at 001 and increment it.)
The program does not put the zero's in except for the one you put in the dialog.
