hi
does anyone know if there is a shortcut for Revcloud. i prefer to type my commands and was wondering if there was a shorter command for it before i create my own.
cheers ;)
type ALIASEDIT then re-map to whatever you like! :D Mines at RV
thanks Zorg
will be changing quite a few now i know of that :D
No problem! I found with some versions of AutoCAD you need to actually click the orginal command or it doesn't pick it up, even if you spell it word for word. Caused my quite some fustration, just thought i'd give you heads up so you dont have to suffer the same :lol:
thanks alot great help :)!
