peshobe Posted April 6, 2009 Posted April 6, 2009 Hi. Can I import all points, picked-up with Trimble total station in AutoCad 2009? I mean not one-by-one, but all simultaneously, using connection via a cable between total station and PC. Quote
Strix Posted April 6, 2009 Posted April 6, 2009 don't you download the Trimble info into it's own software as maybe a dxf then import it? Quote
Bill Tillman Posted April 6, 2009 Posted April 6, 2009 I don't know much about a direct cable connection method, but if you get the point data into an Excel file, there are several LISP files which will easily import them into ACAD available. Quote
peshobe Posted July 1, 2009 Author Posted July 1, 2009 Sorry, Bill Tillman, I tried to enter the raw data in Excel file, but the way they look is not acceptable. Can you explane more how to enter these data in Excel? Quote
eldon Posted July 1, 2009 Posted July 1, 2009 Sorry, Bill Tillman, I tried to enter the raw data in Excel file, but the way they look is not acceptable. Can you explane more how to enter these data in Excel? If you want a one step solution, then you should be using the Trimble software Trimble Survey Controller. It only costs! For those of us seeking a more economical solution, the usual way is to download the data as a text file, and then import into AutoCAD. There are more lisps that use text files than use Excel format. You say the way they look is not acceptable. Could you say what is not nice? Quote
peshobe Posted July 1, 2009 Author Posted July 1, 2009 the way they look is not acceptable. I successfully entered the data in an Excel file, but neither AutoCad nor LisCad open the file with measurements?! Quote
eldon Posted July 1, 2009 Posted July 1, 2009 I am getting confused here, but I guess that you mean is that when you imported the Excel file into AutoCAD, you saw a spreadsheet in AutoCAD. Not very useful for you, but that is what happens with Excel. DO NOT USE AN EXCEL FILE unless Bill Tillman would be so kind as to outline his method. First of all you wanted to download from the total station directly into AutoCAD. If you have paid lots of money for the software that belongs to the total station, you probably can download a DXF file. Most surveyors that I know download the X, Y, Z data file as a text file. Then using a Lisp routine, that file is turned into points in AutoCAD. One very good lisp site is Jeffrey Sanders and he has a very good lisp called IMPORT XYZ. Quote
peshobe Posted July 2, 2009 Author Posted July 2, 2009 Hi, Eldon, I opened the program citied above which got the data from the Total stations, but it shows only the Z-values in the spreadsheet?!. Quote
eldon Posted July 2, 2009 Posted July 2, 2009 I do not understand what data you have got. Could you please post your data file that you have downloaded from the total station. Quote
peshobe Posted July 3, 2009 Author Posted July 3, 2009 0001 INPUT T_ 0 P 948 PC -0.018 0002 KN STAT 0003 A 0 X 51455.581 Y 43574.864 0004 A 0 Hz 121.4115 V1 98.5810 0005 Om 198.0085 0006 S 0 X 51362.081 Y 43817.644 Z 0.000 0007 POLAR 0008 INPUT m 1.000000 0009 10 SD 103.070 Hz 127.3025 V1 100.0215 0010 10 X 51319.220 Y 43911.380 Z -0.034 0011 KN STAT 0012 A 0 X 51362.081 Y 43817.644 0013 A 0 Hz 201.6705 V1 100.4065 0014 Om 274.3680 0015 S 10 X 51319.220 Y 43911.380 Z -0.034 0016 KN STAT 0017 A 0 X 51362.081 Y 43817.644 0018 A 0 Hz 327.3035 V1 100.4055 0019 Om 0.0005 0020 S 10 X 51319.220 Y 43911.380 Z -0.034 END There is slightly disarrangement after "copy-paste". Quote
eldon Posted July 3, 2009 Posted July 3, 2009 That download is not very useful for putting into AutoCAD. It tells me that your length units are metres and your angular units are grads, and the actual measured angles and distances are recorded together with other information. You will have to explore your total station, and find out how it will download a coordinate file with point numbers if you have them (point numbers are necessary to identify points when they are in the drawing). Until you have found that out, then I cannot help you. Quote
peshobe Posted July 4, 2009 Author Posted July 4, 2009 Hi Eldon, Maybe I chose a bad example. I get the co-ordinates from my Total station normally. At Monday morning I'll be at office and I'll send the proper file. Good bye for the present. Quote
Bill Tillman Posted July 5, 2009 Posted July 5, 2009 Try this link http://www.jefferypsanders.com/autolisp_IMPORTXYZ.html This one will import from a text file or directly from an Excel file. Quote
