Can an Attached PDF be faded during printing?
AutoCAD 2010.
I have an attached pdf reference attached to my autocad file. It is for back ground.
In 2010 you can fade the pdf attachment on screen. How can I print that pdf
attached with fade? Is that possable?
Thank you,
AutoCAD 2010.
Thank you,
If it's a vector PDF, then no. If it's a raster PDF, then try putting it on a layer with a color that has a dithered screening percentage in the Plot Style. This works with me for TIFF.
How do you make a Raster PDF vers a vector Pdf. I have been using PDF attach
at the command prompt to bring the pdf's in.
A vector PDF is one that's created directly from AutoCAD. A raster PDF is a document that's been scanned in, sort of like an image. Converting the PDF to TIFF will actually be your best option. I know for a fact you can screen a TIFF image where it's "faded" when you plot.
Can pdf files attached in 2010 be viewed in AutoCAD 2009??
Never tried. Since we've all upgraded to 2010 we've ridden 2009, or at least I did since. I doubt it tho....
  • 11 months later...
Yes if you are on subscription then you just need to download & intall AutoCAD 2009 - Bonus Pack 2 - PDF enhancements. Check out this article on-line:
http://cadpanacea.com/node/79
Paul Li
