kinglevel Posted November 22, 2009 Posted November 22, 2009 Hi. Parameters is a wonderfull thing.. It can be very simple or very complex with links etcetc. BUT.. Im running into this problem all the time, it takes time to load the parameters dialog box. And i load it very often to check values etc. in the end its a lot of time. Is there any plugin/script that places a box with current open part parameters at the bottom or something? it would be a very great solution. Or how do you do it? Cheers Quote
JD Mather Posted November 23, 2009 Posted November 23, 2009 Or how do you do it? In almost all dialog boxes where you can use a parameter there is an expand arrow and then List Parameters which gives you a list of parameters that you can select one of to enter into the box. And this has become really powerful in 2010 where you can name parameters on the fly. Quote
kinglevel Posted November 23, 2009 Author Posted November 23, 2009 In almost all dialog boxes where you can use a parameter there is an expand arrow and then List Parameters which gives you a list of parameters that you can select one of to enter into the box. And this has become really powerful in 2010 where you can name parameters on the fly. yes im aware of that feature, but what if you wanna change a parameter fast on the fly? i dont wanna go into the slow parameters dialog all the time Quote
